'77 280z aka Project Tetanus (LS6 383, T56)
First of all, hello! I'm a newb here but not to modding. I've lived on the norotors forum for the past few years after building a couple of LS swapped RX-7's. I still have my FC (Solid axle, 4-link, LS1, 88mm turbo, TH400) and I'm trying to sell it to fund this project.
Anyway, I came across a '77 280z that had been sitting for 20+ years. From what I can tell it was silver from the factory, then red, then silver again. Lots of piss poor bondo work and rust. Lots of rust. But, for the price I got it for, I can't complain. I've already started cutting the floor pans out.
I have a torn down LS6 that'll be worked into an 11.0:1 382 with a custom BTR cam and a T56 waiting once I get the body sorted. I've had good luck with MS3Pro on my RX-7 so I'll probably go with that on this one as well.
***Will be updated as build progresses***
Parts/ build list so far:
Body/Chassis/Suspension:
New rockers, rear quarters, shaved rear bumper, new floor and trans tunnel, lower doors and front fenders patched
Silvermine Front and rear stage IV brake kits
SS braided lines
CX racing coilovers
New wheel bearings front and rear
ARP extended studs
Tubular frame rails (firewall back) and roll bar with additional supports throughout
Boxed in front frame rails
Energy Suspension full bushing kit
Wilwood Clutch and Brake MC
Wilwood brake adjuster
T3 rear sway bar
T3 front drop links
T3 RLCA's
T3 TC rods
T3 Mustache bar
T3 drop mounts and wishbone
Engine/ driveline:
464rwp/ 448rwtq on E85
LS6 based 383 - K1 crank and lite weight rods, Wiseco pistons, ~11.8:1 compression
Wagner CNC Ported 799's (300+ CFM)
Del West Ti Valves
Texas Speed custom grind: 246/248 on 116+0 .615/.615
BTR Springs, pushrods and trunnion upgrades
1.875" custom SS 4-1 headers
Full 3" SS exhaust
OBX 52mm ITB's with some Jenvey components
ATI Damper
MS3Pro Evo - flex fuel sensor, tuned on pump E85
Walbro 450lph in tank pump
Snake eater 80#/hr injectors
Aeromotive FPR
AN fuel lines
F-Body Camaro fuel tank
Champion 3 row radiator
WHP 300M 39 spline stub axles and Z31T adapters
WHP Chromoly shortened Z31T axles
MFactory Helical LSD
Monster Stage 2 clutch/ flywheel
GTO T56 with f-body shifter setup
Tick Performance Shifter
Interior:
Weld in roll bar
Speedhut gauges
NRG wheel and quick release
NB Miata Dash and center console
Summit reclinable seats with sliders
Racequip 5 point harness
Wheels/ Exterior:
Rota RBR 7.5" Front/ 8.5" Rear
MSA front bumper and rear wing
Skillard side skirts, grill, front and rear diffusers
Edited by SH4DY
Added more parts
On to the pictures:
The Z as she arrived in all her glory/ misery. I'm pretty sure the car was used for practice by a highschool body shop class
IMG 20170603 134229349
IMG 20170603 134222274
IMG 20170603 134211504
IMG 20170704 150404913
Who needs metal for a floor board?
IMG 20170708 133558456
IMG 20170708 133608350
and the rust... ohhh the rust:
IMG 20170708 165546835
IMG 20170708 165539991
IMG 20170708 165524566
IMG 20170704 163820447
IMG 20170704 134409194
IMG 20170704 134358135
After some cutting/ sanding and priming:
IMG 20170711 183358474
IMG 20170711 191057463
IMG 20170708 133628587
I'm also redoing the steering wheel. Took off the old gross rubber, attached some MDF and started shaping. It'll eventually be wrapped in carbon.
IMG 20170609 211103594
IMG 20170611 113814840
IMG 20170613 195957824
Lots and lots of hours to go with the media blaster and sander.
With the several layers of epoxy resin, and maybe a coat of clear, it should be pretty well contained
EDIT: I'm nixing this idea in favor of a something with a quick release.
Edited by SH4DY
I was able to get a little more done last weekend.
I cut out the horrible patch job on the outside of the drivers side frame rail, blasted, primed/painted and boxed in with 16 ga (I think? may have been thicker) sheet. I still need to do the small portion in front of the cross member mount.
7 19 17B
7 19 17C
7 19 17D
7 19 17E
After spending a couple of hours fighting with all the spot welds trying to remove the brackets in the engine bay I gave up after seeing how weak/ think the metal was. It also became pretty clear how flimsy the shock tower support must be. So, I cut a healthy chunk of it out (pretty close to the perimeter spot welds) and added new sheet (22 ga) along with some 3/4" tube. Once I get around to the fixing/ replacing sections of the firewall I'll add bracing to the back of the towers to the firewall.
7 19 17F
7 19 17G
7 19 17H
Also shaved the drip rail. Still very much a work in progress
7 19 17A
  • 5 weeks later...
More welding for the drip rail: Trying to make this car as solid as possible with minimal bondo. Huge pain in the ass.
IMG 20170810 202604527
Added some angle iron to help strengthen the front frame rails:
IMG 20170730 150049422
After boxing in the lower portion of the rails I added a tubular piece to replace the factory frame rails. It is attached to the rear subframe.
IMG 20170730 132214067
IMG 20170730 130947468
Mocking up the motor and the new subframe for the LS swap.
IMG 20170818 142749299
IMG 20170818 142759933
IMG 20170818 142735514
IMG 20170818 142814785
IMG 20170818 174825157
IMG 20170818 174835700
I had some extra paint in the gun and wanted to see what it would look like on the car:
IMG 20170818 171547512
Rustoleum Satin black mixed @ 15% with Acetone. Single coat. I like it. I think it'll compliment the carbon fiber well.
Now that I have the motor in I can figure out the transmission mount and then start building the floors and tunnel.
  • 4 weeks later...
Started boxing in the former battery tray area:
large.IMG_20170905_171148684.jpg.f14a68883072a826ec8135f863d4f558.jpglarge.IMG_20170905_171117864.jpg.3f3021c7ed3580819929547e090db350.jpg
Trans is in! Going to have to redo the majority of the trans tunnel.
Next step is to get a bead roller and start on the floors and finish the firewall.
I think I might wind up going SLA ford 8.8": I started pricing out 5 lug conversions, brakes, suspension, LSD, axles, etc and its pretty cost prohibitive to keep the IRS. Pretty sure with a good 4 link and watts setup I can get this thing to handle pretty well... at least for any auto-x or back road driving I may do.
Edited by SH4DY
I decided to cut out those two rods. The one was right on the panel and it was was already trapping trash and was going to make smoothing the area a shore. I'll be adding a another down bar but it'll be a single curved 1.5" dia tube.
Made some progress (?) on stripping, blocking, priming the body. Still a long way to go. Hope to have it primed by the end of the weekend. Then on to the floor pans and trans tunnel...
large.IMG_20171009_203732441.jpg.8dccd254824fc1fb3fe57f925743d163.jpglarge.IMG_20171011_201958567.jpg.ae798301c044fe2389bb57c2b4bfaf9e.jpglarge.IMG_20171011_201929787.jpg.3e88648b0f17dc74f49b7caebb0d7226.jpg
So, after allll that work I decided it was best to just take it all back to the metal and start from scratch. The car has had at least 3 paint jobs and all those layers added up. It wound up being more trouble than it was worth trying to smooth out that mess or find a  "good" layer. I'm glad I did though - it's going to make life much easier in the long run.
large.IMG_20171015_124236611.jpg.e94ed53ffdfc12cc2762492ce4f0192b.jpglarge.IMG_20171015_155929414.jpg.b59621e04a1855e6164ba23a2bffe378.jpg.
Painted the underside of the hood. There was some trash that got in the gun so the spray pattern wasn't great but I'm hoping I can clear it up with a little wet sanding.
Finally started working on patching the firewall. Still a lot of grinding to go but she's coming along. It's good to not have that gaping hole anymore.
large.IMG_20171015_155954805.jpg.72cca60e120b9cbc6d699f3dd11f5c48.jpglarge.IMG_20171015_160010633.jpg.9674f5ef9b4c5b12409406181fa7ad04.jpg
  • 3 weeks later...
Started working on the roll bar. It's a "Jegster" kit that I'm making fit more to my liking.
I tacked it in place to the car and welded in most of the bars then removed so I would weld all the way around the top. The bottom of the "X" will be installed once it goes back in car.
Did a little porting on the 241 heads:
large.IMG_20171030_204738169.jpg.66520ee347c2ebfa93578b892a5cc809.jpglarge.IMG_20171101_214001755.jpg.98acc413323b04a69690f563075066b6.jpg
I also found this mess after I decided to take the entire car back down to the metal:
It looks like it had a panel replacement at some point with metal that was run over repeatedly on a gravel road. Solid 1/2" of bondo covering it. The body line break was all bondo. I've ordered new quarters and rockers. I think it'll be much easier to replace the panels than try and fix them at this point. Once the panels are in I need to order seats to figure out brackets and then then the floor pans/ tunnel can get finished.
I'm planning on starting on the headers soon. It's going to be a tri-y and 180* design combined. Should be interesting.
Progress is slow but it's progress...
  • 4 weeks later...
Passenger side header after coating. I'll be using slip fit connections for the 180* merge under the car into the collectors. Thinking about going with reverse megaphones. I'm making sure all merges are properly fitted - the outer plate is just a cover to help prevent any stress cracks.
Drivers side before coating. It's a tight fit the the brake MC but I'm not using a booster which helps.
Passenger side installed:
New rocker mocked up:
Rust bullet applied to the replacement quarter and rocker for the drivers side:
Inner rocker being reworked. Close to being able to get the floor pans in.
I've got lots of early X-mas presents showing up: Silver Mine front and rear brake kits, bushings, coilovers, and seam sealer, epoxy and high fill polyester primer.
Edited by SH4DY
  • 3 weeks later...
Drivers side header before coating. Still need to add the crossover piece and tabs to lock in the slip fit connectors.
Reverse cone collectors. Pretty pumped about these.
First attempt at making dimple dies. Very DIY setup: a big bolt in a vice, an old bearing and race and a big ass wrench. I'm going to be adding them to the roll bar around the "X". Need to get a smaller bearing/ race for smaller areas.
More rust, rust rust:
IMG_20171217_184456617.thumb.jpg.c34d1a6c60867dbf8c7a09c28f8e58a3.jpgIMG_20171220_223826688.thumb.jpg.a33defca185edf401e28eadf4e5e918d.jpg
I finally moved the car into the garage. It's getting cold here.
Got the roll bar in and started stitch welding the existing panels that were in good shape and adding more metal for rigidity. I'll be adding some gussets to the "X" and adding additional bars. Also, starting working on the floor pans with some DIY metal forming. Crazy how much stiffer the sheet is with the formed areas. I also had to make more room on the top of the trans tunnel for the bell housing.
This weekend I hope to finish up the roll bar and get both rockers finished then I can start on the floor pans and rear quarters.
On to the pictures:
Edited by SH4DY
  • 7 months later...
It's been a while since I've posted anything but not because of a lack of progress:
Floor and tunnel are done. I took everything back to base metal and epoxy primed:
IMG_20180708_240926085.jpg.
Some added reinforcement:
TTT Goodies
WHP Chromoly 39 Spline stub axles and Z31T CV conversion. New wheel bearings all around
MFactory LSD is in the mail (Thanks to user exlifesaver)
Block is back from the machine shop and I've started the short block assembly. Still need to finish working the heads before I take them to get valve job done.
Still have a ton of body work to go before I can prime but she's coming along.
Little teaser shot of the ITB's
Edited by SH4DY
  • 5 months later...
Some updates. Progress has been slow in the winter months but its still coming along.
MFactory LSD:
F Body fuel tank installed:
Engine bay is done:
Motor is together: K1 lightweight rods, Wiseco pistons, Wagner CNC'ed 799's w/ Ti Valves (should flow 320+ CFM):
  • 3 months later...
