jkelly Posted October 17, 2017 Share Posted October 17, 2017 When you guys have done a 240z to EFI conversion whether it's MS or stock ECUs where do you route the EFI harness through the firewall? Do you cut a new hole near the brake booster or repurpose another hole? Looking for ideas. Thanks Quote Link to comment Share on other sites More sharing options...
madkaw Posted October 17, 2017 Share Posted October 17, 2017 A lot of early Z’s had holes under the battery tray for A/C , that’s what I used . I also used the choke cable hole . I used the choke hole for sensor wiring ONLY . I fed all power and grounds under the battery. With MS there was two harnesses and almost 80 wires I think , but you don’t use all of them - more than likely - so I condensed inside the car and fed only necessary wires thru the firewall. Quote Link to comment Share on other sites More sharing options...
jkelly Posted October 18, 2017 Author Share Posted October 18, 2017 15 hours ago, madkaw said: A lot of early Z’s had holes under the battery tray for A/C , that’s what I used . I also used the choke cable hole . I used the choke hole for sensor wiring ONLY . I fed all power and grounds under the battery. With MS there was two harnesses and almost 80 wires I think , but you don’t use all of them - more than likely - so I condensed inside the car and fed only necessary wires thru the firewall. That engine bay looks good! Do you have a build thread or more pictures? Thanks for the ideas. So you just don't run AC? Good call on separating power wires from signal wires -- avoids any potential for noise coupling. Quote Link to comment Share on other sites More sharing options...
madkaw Posted October 18, 2017 Share Posted October 18, 2017 Quote Link to comment Share on other sites More sharing options...
