Priming fuel pump
HOLLAATYABOYY1
I tried doing a search with no clear cut answer.  Does anyone have a write up on how to purge the fuel lines  in order to remedy a no start issue from empty tank? I want to try this before I start changing pumps and filters.    1976 280z
thanks
Edited by HOLLAATYABOYY1
Added info
Purge the lines of what?  The EFI is self priming, you just cycle the ignition a few times.  The pump will run for a few seconds after turning the key on, turn it off and do it again until you can hear the lines pressure up and you are good to go.
Edited by SleeperZ
The 1976 280Z doesn't have the priming feature.  It came on the later year 280ZX's.  And often doesn't work, after all of these years.
Take the small wire off of the solenoid and turn the key to Start.  The pump will run but the engine won't turn over.  It's described in the Engine Fuel chapter of the FSM.
Small wire off the starter solenoid ? And do you have a link for FSM?
  • 1 year later...
disconect battery from car and fuel pump as well so nothing has power... get a 11v rc battery rig a power/neg make sure its the right way or pump will run backwards... conect to battery and there you go. no more then a couple seconds at time tho... or just sit in car and turn key off n on like your suposre to....lol
