stony Posted July 23, 2002 Share Posted July 23, 2002 Ok folks i finally gave up on tuning by the seat of the pants and went to a dyno (only one in alaska) to tune the 680cc injectors. base run produced 343HP on my tuning which i might add would have a headache after driving had a consistent 10.0-10.5 AF ratio!!!!! last run after getting timing and af ratio right at 12.3-12.7 all the way thru increased to 353HP. the biggest increase was over 50hp at around 5000rpm!!!!! the rest was increased by 20-30hp all the way thru till the top end of the run. this saturday its off the the track to see how it runs. it feels much stronger after the dyno then it did before and feels much stronger even on my tune then with the 444cc injectors which i ran a best of 11.1 @121mph So with any luck and some good traction should get a 10 sec slip i hope. Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 23, 2002 Share Posted July 23, 2002 Awesome! Must be nice to tune on the fly like that! Good luck on the 10s! Quote Link to comment Share on other sites More sharing options...
z ya Posted July 23, 2002 Share Posted July 23, 2002 Thats sweet man! I just had mine done last weak and I was 10.0's across the board as well! Put down 275 rwhp. Praying for 300 or so after I get the a/f in the 12.5 to 13.0 range. Also timing was at 32 when optimal should be around 36 total for a sbc. Next time I will come more prepared! Timing light and jets! Again, congrats on the sweet #'s! By the way, as mine sits what kind of ET do you think I am looking at? The z weighed in at 2700 with me in it. Quote Link to comment Share on other sites More sharing options...
stony Posted July 23, 2002 Author Share Posted July 23, 2002 i dont mean to sound like im braggin (I am) but i have to remind everyone this is a stock motor, stock turbos running stock booste (10PSI) with and intercooler and SDS, if I dont get 10s, well looks like a electronic booste controller and some extra booste. Zya as far your times do a search on the internet for horsepower Calculators and input your wieght and HP should give you an estimate on times. ALthough mine wasnt very accurate... im weighing in at 2700-2750 and with my previous times it said i was running in the 450+ RWHP Id understand 20-30 Hp but 100 maybe im not as heavy as i thought Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 24, 2002 Share Posted July 24, 2002 Dam, would you guys volunteer to do my car? I want some numbers like that. I'll provide the engine, car, and beer just provide the knowledge. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted July 25, 2002 Share Posted July 25, 2002 Hoping to hit the dyno with the Supra this weekend, we'll see. Want to do it when it's cooler in the morning. Last time I made 390RWHP and 427ftlbs. I should be over 400 now if I can get the A/F right. It was 10:1 and below before and corked up with a crappy MAF sensor breathing hot air. The 383 in the Z without the secondaries opening was only 300RWHP Hoping to fix that with EFI sometime soon darn it. Time to turn up the boost man! How much you running now? Slap a nice MBC on it and bring it up some. Still running ceramic turbos? Quote Link to comment Share on other sites More sharing options...
stony Posted July 25, 2002 Author Share Posted July 25, 2002 still running 10 psi on the ceramic turbos. for some reason the MBC i have GReady, isnt working one click its stock the next click it overboosts!!!!not sure whats going on there. think it might have something to do with the rb26 actuators. im gonna invest in a EVC soon . im pretty sure well be able to get it over 400 rwhp with some extra booste but only time will tell. Going to teh track saturday for the real test now if it would just stop raining ill be ok... Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted July 25, 2002 Share Posted July 25, 2002 Try using a fish tank bleeder valve If it's a MAP based EFI this will be no big deal. There are plans out there to build an MBC if you're interested I can dig them up. Quote Link to comment Share on other sites More sharing options...
pparaska Posted July 26, 2002 Share Posted July 26, 2002 I used to run a fish tank type bleeder valve on my Eclipse GSX. This ends up doing much the same thing as the OE solenoid/bleeder - it's always letting some pressure get to the wastegate, and therefore, starts opening it before the bleeder becomes too much of a restriction and makes 99% of the boost get to the wastegate diaphram. Much better is a relief type manual boost controller (MBC). These won't let pressure get to the wastegate until the set point is hit. Low speed torque and driveability is greatly improved over the OE bleeder or the fishtank bleeder. Quote Link to comment Share on other sites More sharing options...
Guest jay240z Posted July 31, 2002 Share Posted July 31, 2002 Stony, Any chance of getting a copy of the dyno sheet posted? Good luck on getting into the Ten's! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 31, 2002 Share Posted July 31, 2002 Hey Stony, Funny story (kinda). My brother and I we're riding around in his MR2 Turbo the other night and we see this black base model Honda del Sol. It had steel wheels and no exhaust (as in nothing past the cat) so we chased after it and got a light. My brother was expecting to smoke this dude, cause a del Sol S is pretty damn slow. We got him off the line, but after that he walked on us HARD. We pulled over and he followed us. Turns out he worked at Hale's (the dyno shop) and has a turbo B16A swapped in. We started talking and he said he knew you and you had been in the shop recently. I asked how much power you were putting down, but he said he didn't want to tell in case you didn't want anyone to know. I figured you'd post on the board, though. I can't remember his name, but he was pretty cool. Anyway, when is the last race down there? We'll be leaving state right around Sept 23rd, so I'd like to come check out your car before I leave. BTW, I will be putting the Z up for sale within the next couple of weeks. I know you were somewhat interested in the spring. It's running a lot better now and I am just finishing a tranny rebuild and I have an HEI to put in there. Anyway, give me an e-mail if you're still interested. Thanks. Quote Link to comment Share on other sites More sharing options...
stony Posted August 1, 2002 Author Share Posted August 1, 2002 i will be at the track for one final shot at tens 10 aug which is teh next to last import race this year. email me at stony7@GCI.NET and let me know how much you want for the Z. go to alaskaracewaypark.com and they have a schedule posted for the rest of the year Quote Link to comment Share on other sites More sharing options...
stony Posted February 28, 2003 Author Share Posted February 28, 2003 Quote Link to comment Share on other sites More sharing options...
Guest spunkysandoval Posted February 28, 2003 Share Posted February 28, 2003 Yo stony, what up? Hey was just wondering what your redline was. What rpm do you usually shift at? Just curious, Isaac Quote Link to comment Share on other sites More sharing options...
stony Posted February 28, 2003 Author Share Posted February 28, 2003 i have the rev limit set at factory redline 7800 rpm i think its been a while since i looked at it Quote Link to comment Share on other sites More sharing options...
