Ls t56 to Chevy 383
Pull the bell housing off the t-56 (easier to handle that a full transmission) and you should see that all of the holes but one should line up from what I've researched. After that your should be able to call a reputable clutch/flywheel suppliers and source the rest off the shelf.
You can also switch the mid plate, input shaft and bell for the lt1 trans if you don't want a hydraulic release bearing.
