What are these wires?
Car: 1982 280zx, auto.
This is where the windshield wiper reservoir would be.  I removed it to clean and noticed a hose and a wire that are open.  Any idea what these are for ow where they should connect?  I checked the Hayes manual and couldnt figure it out.
The one on the bottom goes into the drivers side fender of the car.  The other goes into the engine. Just dont know where.
Thanks
my 83 had the single reservoir master cylinder also and the original reservoir had a plug on it as you can see in this pic, there is the cap, then the other black thing on top was were the plug went for the fluid level sensor. when i got a new reservoir it was not on there anymore. i think someone replaced yours before that why its not there anymore. and the other hose is for the rear window washer at the top of your rear window. there are 2 plugs below the hose that you dont have circled, i believe cause you know they are for the washer tank
Edited by G-Tech
