Sign in to follow this
taaron
Welded Dash
Has anyone ever taken the dash core support out of the foam, cleaned it up and sealed it off with new sheet metal and used that as a dash?
Im running a megasquirt and have planned on using it with a tablet to replace all my gauges anyways.
Share this post
Link to post
Someone here did something similar (full dash cap vs sheetmetal).....not exactly the same, but similar concept.  Final product should be a good bit lighter than the stock dash.
Skillard produces custom gauge pods, which may be helpful for your gauge mounting.
Share this post
Link to post
I have the print files somewhere to make the gauge pod adapter to mount the tablet right behind the wheel. You could also just run a bent sheet of metal folded at about a 90* and make brackets to the mounting points, unless you need the core to mount the radio, fans, etc.
Share this post
Link to post
