Shift boot for FS5W71C swap + B&M shifter.
Derek
4 hours ago, jonbill said:
The rubber seal on the body where the gear stick comes through? I just rotated mine 180 degrees and made new screw holes.
Yes the rubber boot. Did you use the B&M shifter? It has a large plastic coupler on the shaft and the boot won't pull over it.
Thanks
Derek
42 minutes ago, DuffyMahoney said:
I did the same, but i ended up hating the B&M so i went back to stock with fresh bushings.
Yea the B&M is kind of a little too clicky if that makes sense. I'm hoping that I adjust to it over time but it's a huge difference from the stock 4 speed.
9 hours ago, Derek said:
Thanks for the help. Did the coupler pull right off? Or was sone sort of incendiary deice implemented:)
I don't think I had to use any power tools :)I do vaguely recall it took me a little while to figure it out, but it was a couple of years ago now! Maybe there was a lock screw somewhere...
