fusion Posted February 7, 2021 Share Posted February 7, 2021 Is anyone running the extra wide marugen shoukai rear flares? https://www.rhdjapan.com/marugen-shoukai-rear-extra-wide-over-fenders-s30-s31.html Would really like to see pics and hear comments. From my research, it appears that 275s are the biggest tire that can fit under the standard size ZG flares, is that correct? Anyone know the max size under the extra wide flares? Thanks Quote Link to comment Share on other sites More sharing options...
calZ Posted February 7, 2021 Share Posted February 7, 2021 People have run 275s in the stock wheel wells. You should be able to get more than that under ZG flares. It's all about offset. Quote Link to comment Share on other sites More sharing options...
fusion Posted February 7, 2021 Author Share Posted February 7, 2021 Thanks CalZ. It appears in that particular case there was custom rear suspension and axle shafts used. Might not be possible without that specific setup? Quote Link to comment Share on other sites More sharing options...
calZ Posted February 8, 2021 Share Posted February 8, 2021 Axles won't matter as long as the spindles are the same. The coilovers definitely help with clearance, though. You can get that done as cheaply as this. https://groundcontrolstore.com/collections/s30-coilover-conversion Obviously it's more money to spend, but if you're going for a particular look it might be worth it to you. You also get the ability to dial in an exact ride height and a custom spring rate. I still haven't answered your original question, but more food for thought. Quote Link to comment Share on other sites More sharing options...
fusion Posted February 9, 2021 Author Share Posted February 9, 2021 The custom length axles and transverse link allowed the spindle to move inboard, thus giving more clearance. Unless I misunderstood what that guy did. Quote Link to comment Share on other sites More sharing options...
calZ Posted February 9, 2021 Share Posted February 9, 2021 33 minutes ago, fusion said: The custom length axles and transverse link allowed the spindle to move inboard, thus giving more clearance. Unless I misunderstood what that guy did. Ah, I hadn't noticed that further down in the thread. I thought you were talking about his original custom CV axles. Sorry about that. Quote Link to comment Share on other sites More sharing options...
fusion Posted February 9, 2021 Author Share Posted February 9, 2021 No problem man. Hopefully there is a clear answer on how wide of a tire can fit in an S30 with standard and extra wide flares. Obviously the wheel offset makes a big difference, but I can buy whatever wheels are necessary. Quote Link to comment Share on other sites More sharing options...
mutantZ Posted March 3, 2021 Share Posted March 3, 2021 These are the rip off of the wider marugens, and I have the real ones now. Its a 295 in the rear, but theres more than enough room to squeeze a 315 back there. 17x10.5's right now. Prob could've gone as far as 11.5 but that would prob be the limit with this offset. Quote Link to comment Share on other sites More sharing options...
fusion Posted March 3, 2021 Author Share Posted March 3, 2021 Thanks Mutant, could you post more pictures? I see you have welting between the flare and body, did you need to do that with the genuine Marugen flare? Quote Link to comment Share on other sites More sharing options...
LB GSZ Posted January 2, 2025 Share Posted January 2, 2025 On 3/2/2021 at 11:35 PM, mutantZ said: These are the rip off of the wider marugens, and I have the real ones now. Its a 295 in the rear, but theres more than enough room to squeeze a 315 back there. 17x10.5's right now. Prob could've gone as far as 11.5 but that would prob be the limit with this offset. @mutantZ I'm looking to fit 315/30r18 in the back of my 240z with the Apex Engineered kit/coilovers. RHD Japan only sells the Marugen extra wide rear in standard thickness (the thinnest)--They don't offer delux or special. Would you recommend ordering the standard thickness extra wide Marugen's or the Jendoza set for the rear? Quote Link to comment Share on other sites More sharing options...
