Gotham22 Posted May 11, 2021 Share Posted May 11, 2021 I am putting the engine back together on my 1978 280z. Ran into a couple of wiring questions. More specifically, I have no idea what they connect to! I have two wires with bullet connectors coming out of the harness near the positive and negative ignition coil wires. One is blue and the other is white. This wire is broken but I do not see what it used to connect to. This mounts to the screw for the ignition coil Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted May 12, 2021 Share Posted May 12, 2021 7 hours ago, Gotham22 said: I am putting the engine back together on my 1978 280z. Ran into a couple of wiring questions. More specifically, I have no idea what they connect to! I have two wires with bullet connectors coming out of the harness near the positive and negative ignition coil wires. One is blue and the other is white. This wire is broken but I do not see what it used to connect to. This mounts to the screw for the ignition coil I would use a test light and use the ignition diagram in the Haynes manual. There are not many leads that connect to the coil and/or distributor. If your wiring is OEM, the wiring diagram may have the color of the conductors. I know my Z31 Haynes manual did. Quote Link to comment Share on other sites More sharing options...
Sanchez Posted May 12, 2021 Share Posted May 12, 2021 From my recent experience with sorting out and selling the L28 from my 240Z, and helping a friend with a SpeedHut gauge install, it seems that even when the Z’s were new (Before previous owners started hacking up the harnesses for whatever reasons) is that there were a handful of stock wires that seemed to serve no purpose and don’t really go anywhere. My guess is that nearly all the harnesses from 70’s Z cars were designed with automatic transmission wiring and factory option wiring installed to save time and money. Unfortunately the Haynes manual doesn’t show these wires in specific diagrams so if you had factory AC originally or if this is a manual trans, you may want to look for for some community made diagrams instead of the Haynes. Quote Link to comment Share on other sites More sharing options...
Gotham22 Posted May 12, 2021 Author Share Posted May 12, 2021 Thanks all for the help. Sanchez, you reminded me of something. I do have AC but it is not installed at the moment. I bet thats where it goes. Quote Link to comment Share on other sites More sharing options...
Sanchez Posted May 13, 2021 Share Posted May 13, 2021 @Gotham22 Yeah the AC wiring complicated the wiring around the front cover a fair on the early Z’s. My 73 240Z had dealer installed AC that had already been removed when I purchased the car. I found about 5 wires associated with it bundled into the harness that were cut and terminated, but visible which made tracing some stuff difficult. And these wires weren’t referenced in the Haynes manual. The 280Z diagram may actually have AC wiring because it was probably a bit more common addition around the end of the 70’s. AC wiring is a good place to start, but have you done any (or previous owner done any) mods to the ignition system? If you have the 280ZX dizzy and module, or HEI module than there are some things that get bypassed and deleted in that area of the harness. On the 240Z it’s the ballast resistor, on the 280Z I believe they would bypass the Ignition Transistor module. That would be another good place to start looking. Quote Link to comment Share on other sites More sharing options...
Gotham22 Posted May 14, 2021 Author Share Posted May 14, 2021 Thanks Sanchez, I do not think the previous owner made an mods to the ignition system. I will take a close look though. Quote Link to comment Share on other sites More sharing options...
AJ M Posted June 7 Share Posted June 7 Good afternoon, I’m having the same issue as Gotham22. I’m new to this thread and trying to navigate this wiring as a beginner. Quote Link to comment Share on other sites More sharing options...
AJ M Posted June 7 Share Posted June 7 Good afternoon, I’m having the same issue as Gotham22. My wire is also disconnected. I don’t know the name of the part. I have a 78 (3/78) 280z. Quote Link to comment Share on other sites More sharing options...
jhm Posted June 7 Share Posted June 7 Can't help with that specific question; but if you don't yet have the Factory Service Manual for your car, you can download free FSMs for all years here: https://www.xenonzcar.com/s30/fsm.html Quote Link to comment Share on other sites More sharing options...
