LD28 Water Pump
calZ
As the title says, I'm looking for a genuine LD28 water pump with the larger impeller. Hopefully someone that bought one back in the day still has it lying on their shelf somewhere.
Edited by calZ
I think the LD28 oil pump is the same as the NA petrol oil pump.
the LD28 water pump is higher capacity than NA petrol and the petrol Turbo oil pump is higher capacity than NA petrol.
you can buy the Hitachi turbo zx oil pump from rockauto.
Edited by jonbill
  • calZ changed the title to LD28 Water Pump
Expand
You are correct. Thanks for that. I must have had oil on the mind last night while typing. A water pump is what I'm after.
Expand
I may be able to locate 1 but shipping would be from Trinidad and Tobago.
