fabrication of fresh air vent "piece"
I am currently working on a 1971 Datsun 240z. The car was a Nevada car until one of the PO thought it'd be a good idea to take it out to Chicago. Unfortunately a lot of rust formed up in the fresh air vent rails but its mostly surface with a descent amount of shallow pitting (por-15 time). PO tried fixing the driver side corner where the firewall meets the A pillar but it all rusted so I had to take the rail off anyways. Any who, the situation I'm having right now is how to remanufacture a piece that is inside of the frame. I'm not sure what's the purpose of this piece other than maybe supporting the rail from torsional forces. Its a bit of a complex bend and not sure how to go about making this piece. Any advice or ideas would be appreciated.
6 minutes ago, rturbo 930 said:
Doesn't look that bad. Why not clean it up and reuse it?
You are correct it isn’t too bad. Just a pain to weld it up again because I drilled 5/16 holes through the spots welds through the frame and this piece so I would need some brass or copper as a back plate. Unfortunately not cheap. Was hoping because I have a bunch of 18 gauge laying around. But I am curious as to what’s the point of this piece as should more be added to the frame to beef it up.
So being the impatient person I am and not wanting to wait I just decided to have a crack at making it.
Decided it was best to make it out of three pieces because I don’t have a sheet metal breaker and it has a curve to it.
Here is the final result. Is it the best looking? No. Does it fit? Thankfully. Will it do the job? I can hope.
Edited by Alexander240z
1 hour ago, Alexander240z said:
Fabrication is my last resort. Big fan of getting multiple panels of datsuns and sticking them together. I must have panels from 4 or 5 datsuns in my garage lol.
I hear ya :) I have been doing so much rust repair over the past year and a half that I feel more comfortable fabricating from scratch now than re-fitting OEM steel. Sounds silly I suppose. I did enjoy it after getting good at it,  so I can’t say it makes complete sense.
I just find it easier because 9/10 it'll fit a lot better than anything I do. Just gotta make sure the metal you're putting back on it ain't rusty itself lol (forgot to do that for the rear hatch area 😅). Also I don't have a sheet metal brake so bending is a bit difficult with my vise.
Here is a tip on bending sheet metal: use a torch to warm it up (does not need to change color) and use a solid surface with a piece of structural steel on top to keep uniform pressure. Then just tap it with a hammer and she will bend :)
i find the Datsun steel welds poorly. Combination of the cold gavlvonize coating they used, the impurities in the steel itself, and certainly the rust hidden between lap joints.
