240z inner window felt seals
  • 2 months later...
On 4/10/2022 at 7:31 AM, turbo240 said:
The first place I looked. Maybe they used to or I'm completely blind.
https://www.rubbertherightway.com/window-channels-sweepers-fuzzies-window-sweeps-fuzzies-9418-ctg.htm
I Had issues until I changed my search terms :) Oldchool guys call these "window fuzzies" hah!
Last one - you trim to fit with a angle grinder. use your old one for angle to be cut. Then use the smallest black pop rivets you can find. The staples are a PITA without the right tool and come loose if done by hand
I bought the stuff below and after cutting my stuff apart from the rubber (it practically fell off) I glued it on with a plastic epoxy. It is thin enough I was able to glue two side by side to ensure there was a very tight seal.
Sourcingmap Window Weather Seal Strip 0.22 Inch Width x 1/4-Inch Thick x 19.7 Feet Length https://a.co/d/9lcueRx
