L28 + Vortec 4200 frankenstein
zboi
Got this back together again. Lash checked and adjusted this time, lesson learned. Still smokes in boost, so looks like this motor's rings are just not up to the task of holding much boost, odd because it makes good compression across the board. At least the oil leaks are gone. Thinking I should sell this motor and find a lower mileage one, this one would be great NA.
Edited by zboi
Looks like the motor is okay after all, 5 of my coils were on their way out and causing some misfires especially in boost. This must have been washing the cylinder and increasing blowby. A set of 6 coils for $60 and things are looking great. Now my VE tables need readjusting, but then dyno.
  • Like 1
  • 3 months later...
Got everything tuned up a few months back, the car runs great, the power feels like its strongly in the 300s, but I can see that the cylinder head is holding the motor back. Quite sure there is detonation, as my computer keeps thinking there is, and the power is not really increasing at all above about 14psi. I think I will add a flex fuel sensor and try adding some e30 or something. I don't have enough injector to go very high on the ethanol content. Then again, it is quick enough as is.
All in all I'm pretty impressed in how much this motor woke up with this setup, the turbo spools so quick that even off idle it feels like a much bigger motor.
  • 6 months later...
  • 4 months later...
So I had moved and left my car behind, but now that I'm back I did some more testing.
I was unsure how accurate the knock sensors were as I was seing knock retard even when the motor was not in boost. Turns out they are 100% accurate. I put in some 104 octane and gave the car a spin. 99% of knock retard was gone. It is now quite obvious why people blow these motors so easily. I was getting knock retard throughout the 7psi (absolute PSI so 7 away from being "in boost") band from around the 3.6K+ RPM when using just 93 octane. I was getting up to 13 degrees timing pulled at higher boost. With the high octane it was only pulling timing at 14PSI boost, with a resulting spark advance of 20degrees.
It will spin tires in 1-4th gear easily.
Everything is verified and accurate and I'm running slighty rich actually. I'm just putting this info out there to help others. So many people scratching their heads replacing head gaskets all the time, this is why. Meanwhile my engine is running 14PSI with stock head gasket, no deck work, no head studs, everything stock with no issues.
To wrap this all up, it made 308hp 358lb/ft at 4510RPM 17PSI. Power was climbing the whole time, but it ran out of injector at 4500RPM so I limited all runs to this.
More power than expected. Plenty of power for the street, but to be safe I will step up to bigger injectors.
  • Like 2
