fusion Posted March 8, 2024 Share Posted March 8, 2024 I put a new steering rack in my car that has right hand inner tie rods on both sides. I bought 2 MOOG ES2109R right side tie rods and they do fit but on the driver's side it's a bit too long and I don't have much adjustment ability. Also its pointed slightly forward as opposed to the passenger side where it points sightly rearward. What is everyone using for drivers side outer tie rod with right hand thread? Quote Link to comment Share on other sites More sharing options...
jhm Posted March 9, 2024 Share Posted March 9, 2024 How about these? https://technotoytuning.com/nissan/240z/high-clearance-outer-tie-rods-datsun-240z-260z-and-280z Apex makes them as well. Quote Link to comment Share on other sites More sharing options...
AydinZ71 Posted March 11, 2024 Share Posted March 11, 2024 @fusion I don’t mean to be patronizing, so please ignore if you have done this repair before. You are aware you will need to thread both sides on in increments (little at a time) until the toe is close, than check alignment? If you bottom-out one side, the other side will thread on but you will not have enough adjustability to match the angle of the front wheel (toe). if you already know this, please ignore. Quote Link to comment Share on other sites More sharing options...
fusion Posted March 11, 2024 Author Share Posted March 11, 2024 Aydin, thanks for the comment. Yes I am aware of this and have made these adjustments before. I did end up determining that I didn't have the rack perfectly centered. Once I made the adjustment, I think I am OK now. 1 Quote Link to comment Share on other sites More sharing options...
