A to Z Posted October 12 Share Posted October 12 I have been building my ATLAS 4.2 for a little while now, and I have an AR5 transmission from a 2WD Chevy Colorado truck for it. I found a good deal on this Z car online. 1974.5 260Z. The "Big Bumper" 260Z car. Build date of 10/74.....so it's really a 280Z to me as the drivetrain is going away pronto. I love that it has the thicker sheet metal in the subframe and all those extra bends in the floor, that is more rigidity, and it already has the R200 rear end with the 3:54 gears I wanted to offset my transmission gears and work better with my engines power band. Yesterday I took the front panels off of it, looked the whole car over and I am amazed. No rust in rails, no rust in doors, no rust in fenders, no rust in rear hatch panel. 5 rust locations and somehow the hatch itself on one side is completely missing from rust. I ordered the patch panels needed from KF Vintage JDM except the under battery tray rounded piece, which I got form Z Car Depot. Also ordered a new hatch from Resurrected Classics. So soon, the shell will be completely done. This is a long term project, but at least I have a home for the ATLAS, and finding this Z so rust free has made it an absolute keeper. I am thinking about the Rocket Bunny knockoff kit. 1400 bucks delivered is a good deal. Opinions on that? here are a few pics: 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 12 Author Share Posted October 12 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 12 Author Share Posted October 12 Quote Link to comment Share on other sites More sharing options...
BerkeleyTrue Posted October 13 Share Posted October 13 I've been considering the 4200 as well. I'm glad to see another build. I youtuber got all the way to tuning his but gave up after he couldn't get it to idle. It looked sweet though. Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 14 Author Share Posted October 14 On 10/13/2025 at 4:51 PM, BerkeleyTrue said: I've been considering the 4200 as well. I'm glad to see another build. I youtuber got all the way to tuning his but gave up after he couldn't get it to idle. It looked sweet though. That's Merle. He still has it. He got it running, and all is well. In the 6 cylinder portion of this webpage is the build of my 4.2. got a good start on the header wrap for the 4200 today. ran out so waiting for more. Quote Link to comment Share on other sites More sharing options...
jhm Posted October 15 Share Posted October 15 On 10/12/2025 at 2:53 PM, A to Z said: No rust in rails, no rust in doors, no rust in fenders, no rust in rear hatch panel Nice find! I really lucked out with my late-model 260 as well (similar vintage and condition as yours), and was super happy with the condition of the shell. My current car (early-model 260)....not so much. 🤣 Looking forward to seeing your progress -- best of luck with the build!! 👍👍 Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 15 Author Share Posted October 15 Thanks jhm. Probably get a lot of mean looks taking such a clean shell and making a hot rod out of it. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 15 Author Share Posted October 15 10-15-2025. Busy morning in the garage. My 260Z gave up its engine and trans to make way for a future ATLAS install. And yes, it fought me A LOT. My new Harbor Freight hoist gave out midway through, but I got it to limp along with 2 floor jacks and a neighbor guy to basically wrestle it out. From now on, engine only....no more transmission attached for me. Yep....I cut the firewall bracing. It was my plan to do so anyway, and to reinforce and make it removable. I measured before cutting it and sure enough it widened 1/4 inch after cut. After I have made the brackets for re-installing the piece, I will simply use a ratchet strap to pull it back to the correct distance and bolt it in with grade 8 bolts. All nice and pretty. reinforced with thick plate steel. Inside the tubing I will put a spacer for the bolt to go through so when tightened it will keep the tubing from buckling. We move forward! 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 17 Author Share Posted October 17 Well my air dam and rear spoiler for my 260Z came in from Motorsport Auto (MSA) today! Replaced my new engine hoist that bent under weight at Harbor Freight, and finished up the turbo manifold header wrap for the 4200. Pretty cool day! Quote Link to comment Share on other sites More sharing options...
A to Z Posted October 19 Author Share Posted October 19 Today I got a good start on the engine compartment, and also fitted the brass oil port screws to the 4200 block. The engine compartment will be factory color, with clear coats, and the engine compartment will be shaved, I also went ahead and bought a rewiring kit for the car form Jeg's. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Wednesday at 09:20 PM Author Share Posted Wednesday at 09:20 PM I started at dark this morning, and got the seats, center console and dash out of the 260Z. prepped the holes in dash and they are now plugged and curing. then I took some time and just gutted the whole area, to include the dash. Finished at 1:40 this afternoon. 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 05:21 AM Author Share Posted Thursday at 05:21 AM tonight I pulled the tape, it had cured enough, it will continue to harden even more. This is not "just filler" or bondo.....it is 80% aluminum filings and 20% resin. It will not shrink, it will not crack, it is hard as a rock. They poured resin over the Pharaoh Tutankhamun's body, and 3500 years later, to get him out of his coffin they had to chip him out......so it is permanent. ALL METAL Filler. wear gloves! It reacts on skin and burns like there is acid in it. Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 05:19 PM Author Share Posted Thursday at 05:19 PM more pics the next morning Quote Link to comment Share on other sites More sharing options...
A to Z Posted Thursday at 05:20 PM Author Share Posted Thursday at 05:20 PM 4200 engine update. Progress pics of my intake. almost ready to go to the polisher! 2 Quote Link to comment Share on other sites More sharing options...
A to Z Posted Saturday at 02:24 AM Author Share Posted Saturday at 02:24 AM Started work on the motor mounts for the Atlas Z car swap. I bought the motor mounts online for a tad over 30 bucks, apparently made for an LS, then I had to chop on them ( doesn't look good )and then made 1/4" thick steel plates for them to bolt to and then plates for the K member. It is all being bolted togther, and will then be welded when done. Next is taking the spare K member and strapping it to the engine in place, and cutting the remaining pieces and marking everything so I can take it to a shop and have it all welded. After that, sI will be doing a lot of cleanup on them to make them look pretty and then the Atlas will be ready to drop in! Once it's in, then everything will be bolted on to it. My remanufactured AR5 5 speed also arrived today, looks brand new.....no bellhousing, so I have to swap the old bellhousing on, and box up the old tranny to send back for the core charge....they are paying the shipping! Pics: Quote Link to comment Share on other sites More sharing options...
A to Z Posted 23 hours ago Author Share Posted 23 hours ago Today I got the motor mounts all done. I used my idea of holding a spare crossmember with spacers under the engine to make the mounts. 3 inches clears the steering rack with a hair of space. I used LS mounts I found on ebay for 32 bucks, and had to chop them up a bit to make them so they would weld over 1.4" steel plate that was cut and drilled to fit the 4200 block. The metal spans that it came with were too short, so I used a length of 3/16 steel bar and cut and drilled them. Then using the bolt, one at a time I pushed them up to the plate and used a sharpie to draw the angle then removed them and cut them down. You have to remember to mark everything so when apart, you don't get pieces mixed up, as the sides are not identical. After that, I boxed up my core transmission and then cleaned up a bit and headed to the other garage for 260 work. I ground off remaining brackets and other pieces that still needed to be removed in the engine compartment, then used a DA sander to get it all sanded down. The old paint etc....well 80 grit wouldn't even phase it, so I had to use 60 grit. I was able to get everything sanded down except for the corners and tight spaces. I have an elliptical sander I bought that I will use next to get all the corners sanded out with 150 grit, then go over what I finished today to let that 150 grit smooth out any sanding marks. After that, I will then slick all the panels with Dolphin glaze, and sand the entire deal in 220 grit. Then 3-4 coats of sandable filler primer to fill in any imperfections, then color, then 2-3 coats of clear. A lot of work, very dirty, but progress was made. Pics: 1 Quote Link to comment Share on other sites More sharing options...
A to Z Posted 9 hours ago Author Share Posted 9 hours ago The Goal in shaving my engine compartment . To be most as nice as this shaved engine compartment. Turbo Tom's old car (someone took the turbo rotary out ). Quote Link to comment Share on other sites More sharing options...
FastFloridian Posted 3 hours ago Share Posted 3 hours ago Wow, sounds like a lot of work, but will look so good. Quote Link to comment Share on other sites More sharing options...
