1974.5 260Z ATLAS build
On the hood for my 260Z project. I will give some clarification. It is meant to be a picture frame. I want an open engine compartment. no hood at all looks unfinished. this is mean to close off the stuff that is mundane and let the engine shine through. black but blue underneath and a fully polished out engine. So, maybe once done you will understand what I am going for. The Behemoth at Z Car Garage has the same deal.....but the blue engine compartment, shaved, will really contrast with the black picture frame.
12-06-2025.  I have boxes and boxes of stuff I have bought for the car, and today was the day to start throwing all the stuff on and make some room back!  First, I had the mobile welder stop by and weld my radiator support back in, and while here, I had a thick steel plate welded on to the top.  It is stronger now than it ever was.  Then it was time to start installing parts on the engine, getting the hood on, rear suspension back in and all 4 new wheels.  I took the dash down from the rafters so I could start on it on very cold days indoors, and it is a lot heavier than I remember......I am going to swiss cheese the frame and lighten it up a bit......I don't need that weight!  Pics:
At Harbor Freight they have carbon stipping discs for the angle grinder.  It takes the paint off like nothing and does not damage the panels at all. it actually polishes the metal so don't forget to hit with some 80 grit to get the mechanical bond back.
I also have the drum sander version from HF also and it strips paint like nothing!!
https://www.harborfreight.com/4-12-in-non-woven-paint-and-strip-abrasive-wheel-70419.html
great job on the progress!
Edited by DAT26OZ
  • Like 1
thanks.  I just picked up that drum sander they sell.  It comes with a 40 grit drum but I also grabbed a 120 grit drum for it also.  I got a good deal on this. 4 core with dual fans made to fit the 260Z I am building.  It's an eBay buy.  Read up on and decided to try the sanding blocks and tape sold by Eastwood that connects you your shop vac and is supposed to eliminate most of the dust from blocking.  Here's to hoping THAT works!
I picked up my bellhousing and serpentine bracket for the 4200 engine today from the powdercoaters. The finish is called "polished aluminum". I had them done because frankly both pieces were ROUGH....really rough. R&S Powdercoating in Colorado Springs came through for me again. Sandblasted it out, masked off the gasket surfaces and did their thing.
