Alternative Gas Cap?
Have been driving my 1970 240Z on the street and track for 12+ years. I've replaced the seal and stock gas cap over the years. But getting the cap 100% screwed down is always a challenge. And there have been times I was sure it was fully closed but it wasn't and had fuel leakage down the rear fender during time trials. To that end, anyone out there installed a more modern/aircraft style fuel cap with a new fuel filler opening? Thanks.
Edited by Sandy455
I have seen some folks add a Ferrrari-style "pop-up" gas cap and filler; but it's not a trivial mod cost- or work-wise.  And it's usually done for asthetics vs functionality, IME.
I'm curious....are you using this style cap?  It's what I use; and have no problem with spillage/leakage at the track, even when the tank is fairly full.  https://www.zeddsaver.com/collections/gas-caps/products/240z-280z-gas-cap-with-retainer-ring
I'm interested to see what other folks have to say -- following.  Hope you find a solution that works for you!!
  • 3 weeks later...
As I understand it he needed a new gas cap for his 1976 280z and found a gas cap from a 2002 BMW that fit his 280z
Understand that in general engineers are lazy people (I could know, I am one) and the wheel can only be invented so many times before you start making similar products. So no I don’t find it weird at all that a gas cap from a 2002 BMW happens to fit on a 1976 Datsun 280z. Hell my 1977 280z is running a AFM from a 1996 Mazda 626! 😂
Similar to what @darom did, I located one of those old Bimmer locking gas caps and gave it a try.  It does indeed have a tight fit on the Z's gas cap inlet; but I found that gas could slosh up and leak out through the internals of the cap during hard cornering when the tank is near full.  IIRC, it's an internally vented breather-style cap.  It didn't work for my intended application; and I don't think it would work for yours.  However, if you want to give it a try, I can dig through the garage to see if I still have it....LMK.
Thank you., JHM . Appreciate the offer. But if you had any kind of sloshing out on the street, then no, it won't work for the track. With a full tank and 40 tread wear tires up to temp at a place like Streets of Willow, every left turn with the car's physics fully loaded right sends a cascade of fuel out of the cap, down the fender, and gets me black flagged off.
Darom -- I think that's the cap that's now out of stock. Unless you have a source for it we don't know about?
Edited by Sandy455
  • Like 1
1 hour ago, darom said:
Yep, that's the correct part number (and the same one I bought for my Z).  Looks like it's still available from multiple sources.
  • 4 weeks later...
I have struggled to find a cap for my 1972 240z and I refuse to spend $200+ for a new one.  I did find this one on Amazon and it appears to fit well --   https://www.amazon.com/dp/B07GZP12SW?ref=ppx_yo2ov_dt_b_fed_asin_title.  My fuel door closes fine and the bayonet mount appears secure.  For about $12.00 for two caps it seems like a good value.  Now, I am restoring the car and I have yet to run the car with the new cap so standby for an update.
Edited by FJOVA
  • Like 1
