J Taylor Posted April 24, 2002 Share Posted April 24, 2002 Somehow my turbo manifold has gotten warped....the fron 2 ports don't line up to the head worth a damn. I slotted the holes for the bolts a little to get me by but this can't be good at all for flow. Noone around can fix it and noone wants to attempt a turbo header. I have several more manifolds but I really don't want to go back to a stock one and I really don't want to port and jet hot another one....plus add the wastegate flange. I would really like to go ahead and spend the money for a real header. Does anyone actually make one to sell or is it going to be strictly a custom job?? JT P.S. How the hell can a cast iron manifold get bent out of shape like this???? Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted April 25, 2002 Share Posted April 25, 2002 And I thought I was the only one. I drilled my junkyard motor's manifold for an EGT sensor and tried to remount it to the head... it wouldn't line up. I ended up reusing my old manifold that does seem to match head -- I couldn't figure out what was wrong with the other one - holes lined up, ports appeared to be in the right place... Oh well, no help Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted May 20, 2002 Share Posted May 20, 2002 the manifolds shrink from the heat and a lot of them cracked from uneven exhaust port temps from gas that had no injector cleaner add in early 80's.i have 2 besides the 1 on my car and 1 of them has been machined flat at by my machinest.i think cartech in texas makes a turbo header but it is bucks. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted May 20, 2002 Share Posted May 20, 2002 I can get you a trust single turbo header for about $1500 new. It is designed to use a Mitsu TDO6 or TDO7 turbo. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 20, 2002 Share Posted May 20, 2002 IMO, the warpage is due to running to lean, which jacks up you egt temps to levels they don't need to be. Cartech has a manifold, but I believe last time I checked it, they wanted about 600 bucks for it. Here is a little simple math for you. Take your injectors, if they are rated by CC, divide that number by 10.5 to get pounds per hour of flow. Multiply the number of injectors by pounds per hour to get the total fuel flow. It takes .5 pounds of fuel per hour to generate one horsepower. I will break the formula down based upon my setup. 420 cc injector dived by 10.5 equals 40 Lbs. per hour. Multiply that by 6 and you get 240 pounds of fuel per hour. Divide by .5 and you get 480 horsepower. That is the theorectical amount of horspower my car could support. Since we know that injector duty cycles over 80 percent can cause problems, take 80 percent of 480 which is 384 horsepower. That is what I should be able to generate SAFELY at the flywheel.If I subtract 20 percent for driveline losses, that gives me 307 to the rear wheels which is what I dyno'd. While this is a crude formulation, it kind of gives me some perspective that I am pretty close to maxing out my current injector, from a safety standpoint. You can run thru this on your set-up and it should give you an idea if you are running out of injector. That is likely why you have a warped exhaust manifold. I would not spend the money on the exhaust header manifold until I had my fuel delivery set-up straightened out, and you will have the same problem with your nice new expensive manifold. BTW, if you are using a rising rate of gain FPR, that is not the way to get the job done. Get an AIC from HKS or somebody, or go to a stand alone with bigger injectors. One 50 lb per hour injector will give you another 100 horsepowers worth of fuel. This is all IMO. Quote Link to comment Share on other sites More sharing options...
Tony240ZT Posted May 20, 2002 Share Posted May 20, 2002 Anyone have pics of the Cartech one, is it setup to bolt on a commen external waste gate? What turbo flange is on it? Why doesn't someone like MSA start mass producing these things and selling them for like $200? How much more expencive could a turbo header cost to make over a NA one? I'd think less since there is less metal. I can see having an external waste gate option being more. Is the main reason because people might want different sized flanges for the different turbos. I think a t3 flange would be just fine for the masses, making room for a hybrid compressor. Quote Link to comment Share on other sites More sharing options...
fl327 Posted May 20, 2002 Share Posted May 20, 2002 i think it would be more for a turbo header just because its turbo. i would like to see one made that didnt cost a million bucks myself. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 20, 2002 Share Posted May 20, 2002 The one I saw was similar to the standard turbo exhaust manifold, although the outlet flange could have been different. I will see what I can find. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 20, 2002 Share Posted May 20, 2002 http://www.cartech.net/exhaustparts.html Here is a link to their page. I believe the picture has one for a Z in it. Appears to be a T04 flange, although I am sure they can come up with whatever you want. Price is 700 bucks. Make sure you have fuel before throwing down that kind of money, or you will be one pissed off MOFO when that thing warps. I have an old BAE one that is warped to hell and back that was on a regular ZX that Hesco built for a doctor here in Bham. According to Hurley, the car would run in the 11's, with stock ZX fuel injection set-up. I think he was talking about the 1/8th mile. Good luck. Quote Link to comment Share on other sites More sharing options...
DemonZ Posted May 20, 2002 Share Posted May 20, 2002 The Cartech piece is not a header. It is a modified turbo manifold set up for full TO4 flange. I believe some of the high cost of a turbo header is that a quality one will be out of SS. Regular mild steel will not hold up well under the heat of turbo abuse. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted May 21, 2002 Share Posted May 21, 2002 Or the weight of a turbo plus the exhaust system that is not supported by hangers. Cartech could probably fab up a header for you too. Might be a little cheaper than the Trust one. Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted May 21, 2002 Share Posted May 21, 2002 I did not see any mention of it, but in case no one is aware, Cartech Is Corky Bell. Quote Link to comment Share on other sites More sharing options...
