Need some welding help...
Guest brad
I bought a cheapo welder to do some exhaust work on one of my Z's. It's a gasless MIG welder made by Chicago Electric, cost about $100 from Harbor Freight. I'm not much of a welder to start with, and this thing is driving me nuts. I can't manage to run a continuous bead. Regardless of how much tension I put on the wire drive, the wire "hangs up" as I weld. The whole spool of wire is rusty, looks like it's been sitting in a warehouse since before I was born. Would this cause it to hang up? If I go buy another spool am I going to be better off, or just poorer and more frustrated?
Get new wire. Don't over tighten the tension. Make sure that the cable is straight. Also set your wire speed just fast enough to feed the weld and no faster. I also have a CE welder and it works great!!
Tim
Especially without the aid of gas, you need a really clean spool of wire to work with. Go buy a new spool, they are ~$10 depending what gauge/length you buy, I'd probably go for something under 30 as you dont need a thick gauge with exaust stuff anywho.
With flux core wire, .035 is the norm. You need clean wire and you need a clean work piece. If this is new exhaust tubing, spray it with brake cleaner before you start welding. I tried to do some repairs on a buddies exhaust with a borrowed Lincoln 100v welder and had same problems. Acts like it just doesn' have enough power! I think if you clean the heck out of it you should have good luck, however. I finally got his done...
