Mudge Posted May 6, 2003 Share Posted May 6, 2003 Well, I tried to see what is up with the clutch pedal inhibitor, there is a sensor in the general area but I'm not sure its the correct one or how it would be hooked up, its right next to the clutch pedal though with 2 wires. I would assume it could be the one, since I know someone who had to swap thiers out to get the car started and running again, getting my head under the dash is no easy task so I think I will leave it at a shrug Quote Link to comment Share on other sites More sharing options...
kenai Posted December 10, 2006 Share Posted December 10, 2006 My lt1 is from a 94 vette but it does have an after cat 02 sensor on the right bank. I know its OBD1 but i hear that some of these years had OBDII stuff on them. I guess i will just put an 02 simulator on that sensor when i finish my exhaust. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted December 10, 2006 Share Posted December 10, 2006 No, just program it out. Quote Link to comment Share on other sites More sharing options...
deja Posted December 14, 2006 Share Posted December 14, 2006 #1 choice 1995, #2 1994, both OBD I, EEPROM - my own car is a 94 but converted to a 95 Opti. Are there any "tricks" to converting from a '94 to a '95 opti? I'm getting ready to convert my Gen1 to a '94 LT1 and plan on tuning up the opti before install anyway. I have a pieces-parts '95 LT1 that has a opti with new cap and rotor and thought I might as well use it if the sawp is fairly routine. Seems like I read somewhere about some dowl pins or something that was different. Quote Link to comment Share on other sites More sharing options...
Bartman Posted December 14, 2006 Share Posted December 14, 2006 Are there any "tricks" to converting from a '94 to a '95 opti? I'm getting ready to convert my Gen1 to a '94 LT1 and plan on tuning up the opti before install anyway. I have a pieces-parts '95 LT1 that has a opti with new cap and rotor and thought I might as well use it if the sawp is fairly routine. Seems like I read somewhere about some dowl pins or something that was different.I did it on my 94 LT1. It takes a different timing cover and possibly a cam as well (The cam is driven differently). Here's a link to a web page that talks about the swap.http://para.noid.org/~muttvette/opti.html Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted December 14, 2006 Share Posted December 14, 2006 If someone was looking to do a mild turbo upgrade on an LT1, could the stock engine management be modded for that application or should one look for a standalone like a Megasquirt? Quote Link to comment Share on other sites More sharing options...
deja Posted December 15, 2006 Share Posted December 15, 2006 I did it on my 94 LT1. It takes a different timing cover and possibly a cam as well (The cam is driven differently). Here's a link to a web page that talks about the swap.http://para.noid.org/~muttvette/opti.html Thanks, the cam part is what I thought. My long term plan is to build the '95 up in my spare time after I get all the install bugs sorted out with the '94 setup. Guess I'll just tune up the 94 opti for now. Quote Link to comment Share on other sites More sharing options...
Bartman Posted December 15, 2006 Share Posted December 15, 2006 If someone was looking to do a mild turbo upgrade on an LT1, could the stock engine management be modded for that application or should one look for a standalone like a Megasquirt? Since no one else answered, I'll take a shot Scottie. With an OBD1 PCM there are a couple of good programs that will allow you to easily adjust just about any parameter you could think of. So the answer would be, yes the stock engine management could be modified for turbo's supercharger's etc. I think there are several power adder (turbo, nitrous, supercharger) type packages out there that use modified PCMs that work great. Quote Link to comment Share on other sites More sharing options...
