Guest ae86drifter Posted May 15, 2003 Share Posted May 15, 2003 thats right i wanna see all your guys fuel cell set up, im about to cut out my spare tire well tommarow with the rotozip i wanna see it all with details, the size (gal) and dimensions of it, how your fittings and lines tap into your return and sending gas lines. and more importantly how you mounted it up. and pics PLEASE! thanks in advance Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 15, 2003 Share Posted May 15, 2003 pics on my site. 16 gal summit cell. Tim Quote Link to comment Share on other sites More sharing options...
z-ya Posted May 16, 2003 Share Posted May 16, 2003 See this thread for mine: http://www.hybridz.org/phpBB2/viewtopic.php?t=19796 Quote Link to comment Share on other sites More sharing options...
Clifton Posted May 24, 2003 Share Posted May 24, 2003 Do you have EFI? I'm running a fuel cell and had to put a sump in it to keep it from starving in the turns. The foam in them just slows the slosh down. You may end up needing a surge tank or sump. Quote Link to comment Share on other sites More sharing options...
tannji Posted July 29, 2003 Share Posted July 29, 2003 BUMP... Also thinking about a fuel cell... would like to see a few different setups... thanks, tannji Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 29, 2003 Share Posted July 29, 2003 Do you have EFI? I'm running a fuel cell and had to put a sump in it to keep it from starving in the turns. The foam in them just slows the slosh down. You may end up needing a surge tank or sump. Most fuel cells (since they are mainly for racing roundy round) have sumps as an integral part of the cell. Although, unless you have the foam (which I don't), you should plan on keeping your tank at least 1/4 full to prevent starvation. Tim Quote Link to comment Share on other sites More sharing options...
blueovalz Posted July 29, 2003 Share Posted July 29, 2003 http://www.fototime.com/inv/CF926650F3A07F5 for cell mounting pics. Quote Link to comment Share on other sites More sharing options...
WHP Posted July 29, 2003 Share Posted July 29, 2003 Can a fuel gauge be made to work with a fuel cell? Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 29, 2003 Share Posted July 29, 2003 Can a fuel gauge be made to work with a fuel cell? yes, but you will have to buy the 'canister' type sender. Tim Quote Link to comment Share on other sites More sharing options...
WHP Posted July 29, 2003 Share Posted July 29, 2003 Thanks Tim, where would I go to find/learn about one. I'm putting a 5.0 EFI in my early 260Z. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted July 29, 2003 Share Posted July 29, 2003 http://www.atlinc.com/racing/accessories.htm http://www.atlinc.com/racing/level.pdf Tim Quote Link to comment Share on other sites More sharing options...
