SHOW ME YOUR FUEL CELL SETUP
Guest ae86drifter
Guest ae86drifter
thats right i wanna see all your guys fuel cell set up, im about to cut out my spare tire well tommarow with the rotozip
i wanna see it all with details, the size (gal) and dimensions of it, how your fittings and lines tap into your return and sending gas lines. and more importantly how you mounted it up. and pics PLEASE! thanks in advance
  • 2 months later...
Do you have EFI? I'm running a fuel cell and had to put a sump in it to keep it from starving in the turns. The foam in them just slows the slosh down. You may end up needing a surge tank or sump.
Most fuel cells (since they are mainly for racing roundy round) have sumps as an integral part of the cell. Although, unless you have the foam (which I don't), you should plan on keeping your tank at least 1/4 full to prevent starvation.
Tim
