what size K&N filter do I want for cold air intake
jmead
I've got a MSA-style cold air intake tube coming from eBay minus a filter. I decided I'd rather have a true K&N rather than the "K&N-style" filter it was listed with. I was wondering what size/shape k&n filter I should get in order to maximize filter size yet minimize the chance of it rubbing on the body or just not fitting entirely. I will probably order this from summit, but if anyone else has any recommendations on a better place to buy K&N filters that would be great too.
how does it come out into the front of the car, does it make a 90 degree bend and point towards the passenger side of the car, if so, you can run any air filter, i assume its a 3" inlet right?
i would use one for a mustang 5.0 , they are HUGE. i saw a zx with one once that was like a foot and a half long!!!! i would like to run one like this someday, but they are dang expensive, like 150 or something like that.
summit is probably your best bet for it.
I bought a round cylinder K&N for my homemade cold air intake with 3" inlet. It is 4" by 9" and from Summit racing was $35. It has a galvanized end cap with a stud for a mounting bracket or strap. The tapered ones are more expensive, so seemed a no-brainer.
Per K&N the formula for air filter size is:
A=CIDxRPM/25,500
A= air filter area
CID= cubic inch displacement
RPM=max engine revolutions per minute
I never knew, but ASSumed the area is the general outside deminsions, not the surface area of all the pleats.
Will Piatt
A=CIDxRPM/25' date='500
A= air filter area
[/quote']
Let's plug some real numbers into the formula. Let me apologize in advance for not remembering my math skills. I'm sure this answer will be obvious to some of you on this forum.
CID = 183
Max RPM = 7000
50.24=183x7000/25,500
I have a K&N part# RF-1039 which has a 6" long round tapered element.
How do I compare the 50.24 to this element?
Just assume that your element is round and not tapered, use the smaller diameter, let's say 3"? and you can do 2*Pi*1.5*6=56.62. You actually have a little more than that because of the taper, but me old brain doesn't recall the formula for surface area of a cone. :bonk: The round one I have, 4*3.14*9=113.04 in^2
  • 2 months later...
