Guest Child_inblack Posted July 12, 2003 Share Posted July 12, 2003 ahhhh. ive been researching the forums about the different options for diffs. theres the r200 (you need to buy lsd), r230 with lsd, or vette rearend. what would be the cheapest and easiest to install. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted July 12, 2003 Share Posted July 12, 2003 R200 bolt in with some stock parts from a 280Z, you dont need LSD but it would be nice Quote Link to comment Share on other sites More sharing options...
Guest Child_inblack Posted July 12, 2003 Share Posted July 12, 2003 so i could buy one from a 280z and install it huh? what parts would i need? i guess i could install it and then add LSD later. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted July 12, 2003 Share Posted July 12, 2003 I did an R-200 swap last year on my 72 240 and I must say it was pretty straight forward. All I got was the diff. and mustache bar. I already had the poly bushings from the master kit which I recommend doing while the stuff is out. You need to turn the front diff mount 180 degrees to work. I'm not sure what year your car is so keep in mind this was on a '72. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted July 12, 2003 Share Posted July 12, 2003 Check out all the posts under the Chassis and Suspension forum. There are lotz of valuable references to this there! Quote Link to comment Share on other sites More sharing options...
David K Posted July 12, 2003 Share Posted July 12, 2003 R200's also came in the 280zx GLL models. Thats fully loaded, full power, etc. Ive had nothing but r200's in my 280zx's. Quote Link to comment Share on other sites More sharing options...
Phantom Posted July 16, 2003 Share Posted July 16, 2003 My LS1/T56 280Z is running the 3.70:1 R200 LSD out of the '87-89 300ZX turbo. Problem is finding them. Option is to get any R200 you want and put a Quaife in but that is very expensive. Other option is to just run any R200 pegleg with the ratio you want (3.36,3.54.3.90)and consider the LSD option later. Quote Link to comment Share on other sites More sharing options...
Guest shuyun Posted July 17, 2003 Share Posted July 17, 2003 Try A datsun comp R190 LSD That is if you can find one. Anyway I thought the several of the R200 Were LSD with CV joints. Quote Link to comment Share on other sites More sharing options...
j260z Posted July 18, 2003 Share Posted July 18, 2003 check out this site http://www.geocities.com/MotorCity/Garage/6212/diffswap/diffswap.htm there are two different r200s. the ones from the 260-280 2+2s, 280s, 280zxs and some of the early z31s all had 10mm ring bolts where as the r200s from z31s and z32s somewhere around late 84 to 89 came with the 12mm ring bolts. Quote Link to comment Share on other sites More sharing options...
Guest Child_inblack Posted July 18, 2003 Share Posted July 18, 2003 Thank u gize very much. This has all been helpful. if theres anything else that comes to mind, do tell... Quote Link to comment Share on other sites More sharing options...
