cam problems
ok this is really p!ssing me off. I just put my head back on and I'm sure that the cam journals are back in there orginal location, but I can't get it in the journals, so what could be wrong? wraped cam, wrong aliminmant, wrong placement of the journals? What do you guys requimend that I do?
tbs
Yeah. The key is to install the cam AND towers together. Then go in steps when torquing the bolts which secure the cam towers to the head, so all the towers are torqued evenly.
Start with a low torque setting, and increase the torque setting each time, all the time checking for smooth cam rotation. If necessary, tap the towers with a rubber mallet to smooth things out, then repeat the procedure until the cam tower bolts are torqued to spec, and the cam turns freely.
Since the head gasket was not exposed to any combustion chamber gases you can re-use it. I would just add 5 ft-lbs of additional torque to the head bolts to further crush it. I have know several mechanics who have used this "trick".
  Quote
Yeah. The key is to install the cam AND towers together. Then go in steps when torquing the bolts which secure the cam towers to the head' date=' so all the towers are torqued evenly.
Since the head gasket was not exposed to any combustion chamber gases you can re-use it. I would just add 5 ft-lbs of additional torque to the head bolts to further crush it. I have know several mechanics who have used this "trick".[/quote']
Just to be clear, you only have to re-do the towers with the cam in them. You should not have to pull the head at all.
