Guest grunt0311 Posted August 9, 2003 Share Posted August 9, 2003 Anyone know if the complet rear end. Meaning the cv's and the rear end (4.11) and hopefully the hubs with the disk brakes will swap onto a 240z? This would make for a quick rear disc brake swap along with cv's and an r200 with the 4.11 gears. Any help would be appreciated. thanks, grunt0311 70 fairlady ugleeeee 71 sold not delivered 74 today it comes to its new home Quote Link to comment Share on other sites More sharing options...
johnc Posted August 9, 2003 Share Posted August 9, 2003 You can probably make the swap happen but it won't be "quick." The diff is a bolt in (both are R180 units) but the CVs and brakes require adapters and you can't use the hubs unless you want to do a lot of machining. Quote Link to comment Share on other sites More sharing options...
BRAD D Posted August 9, 2003 Share Posted August 9, 2003 If it is an 200SX turbo i might be an R200, then you would need the M-bar from a 280Z. And to fit the rear disks you would need some custom brackets. Quote Link to comment Share on other sites More sharing options...
Guest grunt0311 Posted August 10, 2003 Share Posted August 10, 2003 Thanks for all the help! I think it is an R 200. From what I understand all the turbo 200sx's come with the R 200. I just guess can I take the cv's too. If so will the the hubs or discs be the same lug pattern as a 240? If so I will take the whole set up and leave the disc brakes on an find a way to mount the rear end differential. If the lug pattern is different will the cv's mount to my drum brakes? Thanks again. grunt0311 70 fairlady 71 sold not delivered 74 mine but rougher than I thought it would be Quote Link to comment Share on other sites More sharing options...
rreford Posted March 26, 2004 Share Posted March 26, 2004 Grunt, what did you find out? I'm heading this afternoon to get the 4.11 diff out of an '85 200SXT and planned to get the CV axles with it. Should I get the hubs/brakes, too? Quote Link to comment Share on other sites More sharing options...
Guest dvlax28 Posted April 2, 2004 Share Posted April 2, 2004 Hey, i recently pulled the drivetrain out of an 82 280zx and i was going to use the r200. now instead, i am going to keep my r180 because it is lighter than the r200, but im going down to the junkyard to pull the gear assembly out of a 200sx (86-87 i heard, not sure) because apparently they fit right in my stock 73 240z r180, and it is a 4.11:1 gearing. anyone have any advice or done anything like this? jason phx, az Quote Link to comment Share on other sites More sharing options...
nullbound Posted April 2, 2004 Share Posted April 2, 2004 if i recall correctly, the cv's from a 200 sx turbo (which will have the 4.11 r200 diff) are the same as the z31 non-turbo cv's. i dont know the difference between the turbo and non-turbo z31 cv's, but the MML conversion kit that Ross C sells is advertised as being for the z31 turbo cv's. as posted earlier, to use the brakes, you will need brackets. Quote Link to comment Share on other sites More sharing options...
j260z Posted April 3, 2004 Share Posted April 3, 2004 the z31 turbo cv's have a 4 bolt housing on the wheel end of them whereas the z31 na's come with the 6 bolt housing which looks identical to the 280zx turbo cv's. Quote Link to comment Share on other sites More sharing options...
rreford Posted April 5, 2004 Share Posted April 5, 2004 the 200SXT cv's (from the '85 R200 4.11) do have six bolts - three sets of two, 120° apart. haven't compared them to turbo 280ZX hubs yet. Quote Link to comment Share on other sites More sharing options...
wAnNaBVaN Posted April 6, 2004 Share Posted April 6, 2004 so can a 200sx 4.11 r200 lsd fit into a 280zxt ? direct swap? thanks Quote Link to comment Share on other sites More sharing options...
