strut spacers, bearings and insulators
just got my coilovers and am trying to get the rest of the parts needed to finish up. i need to order new strut mount insulators and bearings, which i can still do through nissan, but i can't find the spacers for my rear struts, which are nla through nissan. i know i can order them through VB but i was wondering if anyone knew what they were made of? my other questions are:
1: i've seen the caster/camber kits from ground control and was wondering whether they would be much noisier and harsher than the stock insulator?
2: i'm planning on getting adjustable lower arms all around and was also wondering if it would be overkill to get the ground control units also?
There is a limit to how far you can adjust camber with an adjustable control arm. The rule of thumb that I was told by one of the engineers at Maximum Motorsports (yes, the Mustang guys) was that you don't want to have the rod ends threaded more than 1.5 times the diameter of the shaft. So if you have a 1/2" rod end you don't want it threaded more than 3/4" out of the control arm. That 3/4" length includes the threads in the jam nut if I remember properly.
If you think you'll need more camber adjustment, then get camber plates in addition. I did it backwards, had the plates, didn't have enough adjustment, got adjustable control arms.
Yes, all of this stuff is loud, but people are usually surprised at how smoothly my car goes down the road. Its not so much the ride, but the noise that is a problem. But I don't have a stereo in my Z either :-D
Jon
On the stock insulators, I can see no gain in replacing them with something else unless you you want a full race suspension or the space they take up is a problem. Consider the degree of compliance they offer which helps protect the body from vibration and jarring.
There is a limit to how far you can adjust camber with an adjustable control arm. The rule of thumb that I was told by one of the engineers at Maximum Motorsports (yes' date=' the Mustang guys) was that you don't want to have the rod ends threaded more than 1.5 times the diameter of the shaft. So if you have a 1/2" rod end you don't want it threaded more than 3/4" out of the control arm. That 3/4" length includes the threads in the jam nut if I remember properly.
Jon[/quote']
The alternative to using stock tie rod ends, which gets over their lack of length, is to make up custom items using male PTFE lined rod ends and some internally threaded tube. Then you don't have to use camber plates and so can retain the stock insulators.
Retaining the stock insulaters also allows you to use road springs of up to around 300 for better handling and still with reasonable comfort and noise levels on the road.
260DET
Am I missing something??? I'm confused.
I've never heard of using a tie rod... how the heck do you use a tie rod as the pivot for the control arm? I don't think its possible, and I don't think I'd want to.
It looks like you are responding to what I said. I said use a rod end. Just like what you are talking about. I was saying though, that you don't want 2" of thread hanging out of the control arm on your 1/2" rod end, even if the threaded portion is 3" long.
You are still relying on the threaded portion of the shaft to take a lot of stress, and the more you have exposed, the weaker it is. The rule of thumb is 1.5 times the diameter of the shaft is the max you want outside of the control arm. At least that's the advice I got from an engineer who works for a suspension fabricator.
Jon
Sorry Jon, I thought you were talking about running out of thread for the stock tie rod ends. Which can happen when, by whatever means, the suspension arm outer pivot point (ball joint) is moved out a lot to gain more negative camber.
Clear as mud now? :)
