Miles Posted November 15, 2003 Share Posted November 15, 2003 While at freeway speed today I noticed that my stock 240Z was vibrating. I could feel the vibration through my seat and through the shifter. The vibration seems to go away when coasting with the clutch in. I feel the vibration just sitting with the car running at different RPMs. The engine runs really good and I recently just installed a set of rebuilt SU carbs from Ztherapy. Any ideas or things I should check for? Thanks Miles Quote Link to comment Share on other sites More sharing options...
datsunlover Posted November 16, 2003 Share Posted November 16, 2003 Could be something to do with the clutch disk.. My 280zx did that and I was told by a transmition guy it could be the disk is off balance for some reason.. (?) or maybe a drive shaft/u-joint issue. anyone else? Quote Link to comment Share on other sites More sharing options...
72zcar Posted November 17, 2003 Share Posted November 17, 2003 transmission mount may have seperated. Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 18, 2003 Share Posted November 18, 2003 motor mount trans mount loose bolts in either loose trans x member loose bellhousing to engine bolts with engine off, push in clutch, if the whole thing moves, bellhousing turn it on, rev engine, watch movement of engine, if it gets a little floppy, there you go. jack up the car, and take a look at trans mount and everything else, i think its trans mount myself, or loose bolts. Quote Link to comment Share on other sites More sharing options...
Miles Posted November 18, 2003 Author Share Posted November 18, 2003 Thanks for the checklist. I'll get under the car this weekend and go through the list. Miles Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 29, 2003 Share Posted November 29, 2003 I would check the harmonic balancer too. I had the balancer come apart on me and one of the pullies where jumping around. The vibration could be felt in the shifter, but not as much with the clutch dissengaged and coasting. It's always good to check just in case. Chase Quote Link to comment Share on other sites More sharing options...
Miles Posted November 30, 2003 Author Share Posted November 30, 2003 Chase The shifter does vibrate less whent the clutch is in. Any way to check the vibration damper or just replace it? Thanks Miles Quote Link to comment Share on other sites More sharing options...
Guest 240hybrid Posted November 30, 2003 Share Posted November 30, 2003 You'll be able to see the pulley jumping around if its failed. I could move the pulley by hand also while the motor was off also. Chase Quote Link to comment Share on other sites More sharing options...
