Large tires killing handling?
  • Replies 44
Guest Nic-Rebel450CA
Isnt it true that the offset and backspacing are going to have more of an impact on the "feel" than the rim diameter ever will? Everyone seems to be referring to rims in this thread like a 17" rim is a 17" rim and a 16" is a 16" and so on. The important part is going to be the specifics on the respective rims. One 17" rim could be extremely easy to turn, and another could be extremely hard to turn even if they are the exact same widths.
  Quote
Now with the added weight of the 17's and the better tires it's like i'm suction cupped to the road. Puddles at high speed are no problem... cut's right through them..
It may SEEM like heavier wheels are helping, but it's the entire vehicle weight that you're talking about here, the total normal force at the tire. And total vehicle weight can't have changed much. Heavier wheels/tires will always result in less grip under dynamic conditions, as the suspension won't be able to control the unsprung mass as well. Lighter wheels/tires will always have better contact with the road in real-world conditions (i.e., bumps, undulations, etc in the road surface). The suction cup feel you describe is likely 100% due to better tires.
  • 2 years later...
I agree the tyre quality makes a huge diference.a narower tyre with better compound (and tread design)will out perform a wider one of inferior quality any day.I love wide tyres but only buy the best tou can afford(and afford to replace if its more than a show pony)The thing nobody seems to be concidering is geomitary .finding the right camber caster toe out front and rear can and will make or brake your cars ability to grip the road and get a good life from the rather large investment in good tyres. col
Tire sizes is always an interesting subject. In the past I talked with BFG and GoodYear and asked them how this works and they both seemed to have about the same answer which actually makes sense.
The senerio is two tires made of the same compound and tread style but one is a skinny tire and the other is a wide tire. Also the side wall are the same compound and flex the same way. What was explained to me is that if you assume the car weight is the same for either tire then the only thing that changes is contact distance. So a skinny tire will have a longer contact distance and a small width distance, which would mean it would have better traction front to back. A wide tire will have a short front to back contact distance and a wide side to side contact distance, which is better for side to side traction. If you really think about this it makes sense because the contact area of the same exact tires, just different widths, will have the same contact area on the ground. Since it is the same contact area the wider one has to have a wider contact distance and a shorter front to back distance.
There are points that must be recognized which is that if you have a skinny tire with very little side wall verses a wide tire with a lot of side wall, the contact area can change because there will be a convex or concave portion that can make differences to the contact patch (just like under inflating and over inflating the tire).
I hope all this makes sense to you guys and if not I would recommend just calling one of the tire manufacturers and they seem to be willing to discuss it fairly easily at least when I called that time they were.
One thing about wide tires on the streets with grooves that are in a some what parallel direction to the direction you drive. The wide tires will tend to catch and track along a groove or edge much more than a skinnier tire does.
in reference to the tyre area in contact with the road
I must disagree
If you need more surface in contact with the road with a lighter car simply use lower tyre pressure.
It is however better to use softer compounds the wider you go
col.
What are you disagreeing with? And you have to consider a lot more when you lower the tire pressure. This will affect how much force the tire can generate, it's stiffness in several different directions, etc. Adjusting the pressure does a lot more than just put more or less area on the ground.
And softer compounds, stiffer construction is the way to go.
Tire temps generally determine tire pressures and to get the most grip you run as low a tire presure as possible while maintaining an even temp progression across the tread and not rolling over onto the sidewall.
With 275/45-16 Hoosier R3S05s on the 2160 lb. 240Z I raced, cold temps were around 25 psi and hot temps around 30/32. That was counter to Hoosier's recommended hot temps around 40 but the pyrometer doesn't lie.
  Quote
So what temps were you getting at pressures of 30/32 and what temps were you supposed to be getting at a pressure of 40? Also how was "grip" quantified? Accelerometer, lap times, driver feedback?
Am I being tested?
Even temps across the tread does not *necessarily* imply the quickest setup. No direct experience meself (not nearly consistent enough to make a judgment, and besides, I'm lazy. I just run conservatively high pressures) but at least one successful 240Z race effort found they had quicker lap times with higher temps on the inside of the tread. Tire sizes were somewhat skinnier than 275, though.
Just playin' devil's advocate! (plus, who am I to resist an opportunity to stir the pot?)
WSIR:
LF (O, M, I) 192 - 199 - 202 / RF (I, M, O) 188 - 178 - 170
LR (O, M, I) 198 - 205 - 210 / RR (I, M, O) 191 - 189 - 181
WSIR's most important corners are all high speed right turns. Turn 9 (the last turn before the pits) is a decresing radius 100 mph right hand corner that's right after turn 8 which is a big radius right hand turn.
Above temps were taken after a series of high 1:27s/low 1:28 laps which is right at the SCCA GT2 lap record for the track at that time. BTW... I wasn't driving, I took the tire temps.
