intercooler pipes
Guest szlash280z
Guest szlash280z
for those of you with intercoolers. Do your pipes have any kind of ridge/barb on the pipes at the couplings to help keep the pipes clamped together? or are they just a straight cut pipe?
I just used straight cut pipe, but I am using rubber radiator hose from a semi-truck as couplings; it is no where near as slippary as silicone hose. If you use quality band clamps with silicone hose then you can get away without beading the piping as they can clamp really tight without damaging the hose. Your joint alignment needs to be quite good, and you can't couple a curved section of pipe however.
Guest szlash280z
ok so those of you with the ridge on the pipe as insurance just had a weld bead welded on to form the ridge? simple enough. What is a T clamp?
thanks for the help!
Guest bastaad525
just curious... how much boost is considered 'high boost'?
I'll be running about 12-13psi once I get my I/C in, and was planning on using radiator hose for couplings and just regular hose clamps... should I worry?
The picture Yo last posted are the clamps I use. You can pick them up at a NAPA auto supply for about $4 a piece. Bring the dia pipe and hose you plan to use so you buy the correct dia. Since they aren't as adjustable as reg. hose clamps. Also a trick I used from installing MTB grips is wipe outside of pipe and inside of hose with alcohol (to get slippery grease/grime off). Then clamp or added ins. apply hairspray (don't know if you young guys remember what that is :D )or even lightly coat with spray adheasive on critical areas. I run 15 to 18 psi. boost no problem.
