240ZinTN Posted February 11, 2004 Share Posted February 11, 2004 I am thinking of buying a turbo from a guy on ebay, he goes by "down2turbo", and I wanted to check to see if anyone here has had any experience doing business with him. If so, are his remanufactured turbos any good? He says he offers a 90 day warranty. Any other good sources for affordable(hahaha) turbos would be appreciated. Here is a link: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6755&item=2459229644 Quote Link to comment Share on other sites More sharing options...
slownrusty Posted February 11, 2004 Share Posted February 11, 2004 Well he has excellent feedback. One negative in the past 6months and 163 positive feedback. His Turbos looks pretty sweet. Yasin Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 11, 2004 Share Posted February 11, 2004 Looks alright, but keep in mind the turbo you linked is not suitable for a Z - the a/r of the turbine is too restrictive (0.48), you need at least 0.63. And the turbine will not bolt up to a Nissan wastegate/downpipe. Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted February 11, 2004 Author Share Posted February 11, 2004 I was also looking at his t3/t4E (see link below) but it looks like the turbine a/r on it isn't any better. I was planning on fabricating my own downpipe. I hope I don't regret it. I still need to find a good turbo if Down2turbo can get me anything I need, what specs would you recommend on a t3/t4e and how much $ is too much Sleeper? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=2459885532 Quote Link to comment Share on other sites More sharing options...
yo2001 Posted February 12, 2004 Share Posted February 12, 2004 .48 AR is going to be too small IMO Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 12, 2004 Share Posted February 12, 2004 Certainly can't complain about the prices. What a good turbo for you depends on your hp level and intended use for the car. I do a little drag racing and road racing, but my car is mostly a street vehicle. The stock turbine with the 0.63 a/r works well but is flow limited, so maximum power is certainly not realized. You need to figure out what compromises you can live with before you can know what turbois good for you. Quote Link to comment Share on other sites More sharing options...
yo2001 Posted February 12, 2004 Share Posted February 12, 2004 I agree with Sleeper. Some people are more tolorable when it comes to slow/laggy turbo which is one of the compromise on a turbo car (power/response) I personally ran a big hybrid combo and never bother me about 3200-3500rpm full boost but some like the boost to be there in lower rpm. I wouldn't be too concern about the flow map as the map chages with different turbine combination. about 60-1 is the biggest you can get on a street car without being overkill. 60 trim, 57 trim, 50 trim are all nice on the compressor side. (more effiecient too in the T04E housing.) Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted February 12, 2004 Author Share Posted February 12, 2004 Well, I can definitely say I don't tolerate lag very well. I do want to get at least 250hp out of the car, and would prefer a broad power range. As far as track performance goes, getting into the mid 13's would be nice. The only Z that really flies at the Bristol Street fights runs an LS1 with nitrous and is semi pro with some sponsors. There is no way I can beat him and still have a streetable 240Z. Something in the 13's would beat my buddies who take their Z up there a couple times a year (by a couple seconds). Quote Link to comment Share on other sites More sharing options...
yo2001 Posted February 12, 2004 Share Posted February 12, 2004 250HP at the crank would be a easy job out of a stock turbo with DP anf IC. You can probably get 250 at the wheel on a stock turbo but you'll be running more than moderate amount of boost to get there. I would first deside where you want your power in rpm's (say 2500-5500rpm) than decide on a size of the turbo. Sounds like you just need something little bigger than a stock turbo. Quote Link to comment Share on other sites More sharing options...
240ZinTN Posted February 14, 2004 Author Share Posted February 14, 2004 I definitely do not want to go too big on the turbo. I still have not been able to find any T3/T4E 's with the right turbine AR. Does anyone have a good source? Quote Link to comment Share on other sites More sharing options...
240hoke Posted February 14, 2004 Share Posted February 14, 2004 talk to the guys at Top End Performance, they can have a turbo built to your specs. They do alot of work with turbo z's and can help you out in picking the right turbo. I'm using a t3/t4 super-h stage 5 .82 turbo. They reccomended this as it can flow enough air for over 400hp. But it is definitly slower to boost then the stock t3, much more power when it hits though and it keeps coming -Austin Quote Link to comment Share on other sites More sharing options...
Clifton Posted February 15, 2004 Share Posted February 15, 2004 I'd avoid Top End. Me and many others have had bad experiences with those *&^%$#, but not to say you will. I wouldn't get to caught up in the lag thing. Even full t4's spool quick enough for a street driven car if you don't go to big. This place has some pretty good pricing http://store.yahoo.com/cheapturbo/gartur.html. talk to the guys at Top End Performance' date=' they can have a turbo built to your specs. They do alot of work with turbo z's and can help you out in picking the right turbo. -Austin[/quote'] Quote Link to comment Share on other sites More sharing options...
