Guest ZmeFly Posted February 18, 2004 Share Posted February 18, 2004 I just got a good luck draw on some of the Z31 parts that I need to complete this swap. I picked up from a freind of the family, a MAF and distributor, well just for the wheel for 15 bucks!! Cant complain about that. As I have done some reasearch and thanks to Yo2001, read some of what he did and looked at his schematics for info. Im at a crossroads so to speak on knowing exactly what I need, as I said I have the chopper wheel, I have the MAF, but what computer?? and from what year etc.? Also something that confuses me slightly is that some suggest the Z31 wiring harness and others say modify the S130 harness, Ive been told it is best to go with the Z31, any comments? Thanks for any help you all can give and or pointers on what to do to make this swap happen. Thanks James Quote Link to comment Share on other sites More sharing options...
yo2001 Posted February 18, 2004 Share Posted February 18, 2004 I would recommend running a turbo ECU. I ran 87 turbo ECU. But all are about same except 88-89 which were 16bit ECU's Don't forget an ignitor. Quote Link to comment Share on other sites More sharing options...
Bernardd Posted February 18, 2004 Share Posted February 18, 2004 Modifying the s130 harness is easier than removing it and installing the z31 wiring IMO. You only have to move a few wires. If you're planning on programming the ecu some 87's and 88-89's are easier to program than the earlier ecu's. Edit: Forgot to mention that the stock single wire o2 will work on the 88-89 ecu BUT you'll have to reprogram it to work with turbo injectors and boost. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 18, 2004 Share Posted February 18, 2004 If you find a turbo ECU '87 or later, and intend to use the O2 sensor (it's a good idea - makes good MPG), it can be expensive - it's different. The other years and types of Z31 ECUs can use the original 1 wire, or a universal heated sensor. Quote Link to comment Share on other sites More sharing options...
Afshin Posted February 18, 2004 Share Posted February 18, 2004 Hello gentlemen Well I finally went for the Z31 set up and have it running It's quite nice, certainly idles better and feels like the power band is slightly broader. Feels a little faster, but not by much (not that it should, maybe 10-15 hp). The throttle response is also improved and it revs nicer. I used a 84 turbo ECU and modified the stock 280zxt wiring. I also have the computer controlling the fuel pump, AMS cleaning cycle and all emission devices (except the inactive EGR system). James, I have a work deadline this week. I will try to do a full clear "how to" write up in the next week or so. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted February 18, 2004 Share Posted February 18, 2004 Hello gentlemenWell I finally went for the Z31 set up and have it running It's quite nice' date=' certainly idles better and feels like the power band is slightly broader. Feels a little faster, but not by much (not that it should, maybe 10-15 hp). The throttle response is also improved and it revs nicer. I used a 84 turbo ECU and modified the stock 280zxt wiring. I also have the computer controlling the fuel pump, AMS cleaning cycle and all emission devices (except the inactive EGR system). James, I have a work deadline this week. I will try to do a full clear "how to" write up in the next week or so.[/quote'] Good deal! Quote Link to comment Share on other sites More sharing options...
Dacelooper Posted February 19, 2004 Share Posted February 19, 2004 i would love to see your write up on that. i've been in the same place for a few weeks now just hesitating on the wiring part. just finished maping out all the change that need to be made and am going to atempt it. but i would love to see your write up before i do Quote Link to comment Share on other sites More sharing options...
Afshin Posted February 19, 2004 Share Posted February 19, 2004 OK Dave, I will have the write up posted within the next 2 weeks and you can compare it to what you had mapped out before you splice any of the wires (I did make a few small mistakes before getting all of it to work properly (eg, fuel pump control). Quote Link to comment Share on other sites More sharing options...
Guest ZmeFly Posted February 19, 2004 Share Posted February 19, 2004 Till I have everything I need, I really appreciate you doing a write up as Im sure anyone else here that would want to do this swap is. I cant wait to read it. Quote Link to comment Share on other sites More sharing options...
Dacelooper Posted February 19, 2004 Share Posted February 19, 2004 OK Dave, I will have the write up posted within the next 2 weeks and you can compare it to what you had mapped out before you splice any of the wires (I did make a few small mistakes before getting all of it to work properly (eg, fuel pump control). thanks, i'll be looking forword to it Quote Link to comment Share on other sites More sharing options...
Sparky Posted February 19, 2004 Share Posted February 19, 2004 I will be looking forward to that as well, looks like my standalone EMS money is going to the "girlfriend" fund. but i can still afford the Z31 stuff. ...just barely.... -S Quote Link to comment Share on other sites More sharing options...
