bogging
evildky
I have driven myself nuts trying to figure this out, I have a 71 240z origional engine, it bogs down once it gets good and warmed up, not overheating just at normal operating temp, I can be tooling along or racing, reving 5000 in second, and it just starts to bog, I shift to third and it bogs at 3500 rpm, speed seems to be the limiter ? I have replaced the points dist with an electronic unit from a 78 and added an aftermarket coil and an MSD 6T, I replaced the factory SU's with a set I got from a totaled IT car, the problem remains, I replaced the fuel pump with a holly red and a FPR, the problem persists, I adjusted the valves it still does it ? I am banging my head, not likely to have 2 sets of bad carbs, not likely to have 2 bad distributor, I am out of stuff to replace, any ideas?
I could be WAAAY off base here, but isn't the 6T the turbo model that retards timing as rpms come up? If your timing were getting retarded you would definitely lose power.
Other than that I would suspect a clogged fuel filter or some other fuel problem.
Jon
