mobythevan Posted March 9, 2004 Share Posted March 9, 2004 A friend just gave me a new in box Hayden tranny cooler. I was going to use it as an oil cooler on my turbo engine. Is there a problem with the tranny cooler tube size? It looks big enough to me, but I remember the outlets for the factory oil cooler being a little bigger. Quote Link to comment Share on other sites More sharing options...
frank280zx Posted March 9, 2004 Share Posted March 9, 2004 My tranny cooler ( eurospecs have them stock) are smaller in diameter than my OIl cooler.. my engine oilcooler has close to 10mm tubing, as where the tranny only uses something like 6mm Quote Link to comment Share on other sites More sharing options...
Tim240z Posted March 9, 2004 Share Posted March 9, 2004 Too much restriction for engine oil. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted March 9, 2004 Author Share Posted March 9, 2004 ok, I can't save a buck then, I'll just buy an oil cooler. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 9, 2004 Share Posted March 9, 2004 ok, I can't save a buck then, I'll just buy an oil cooler. You can save a buck if you want to use a DSM oil cooler. I was going to use it until I found a factory ZXT unit. The inlets look to be about 5/8", plenty big, similar to the ZXT. I got some spare parts if you need them. Quote Link to comment Share on other sites More sharing options...
Tony D Posted March 10, 2004 Share Posted March 10, 2004 Factory ZXT Engine Oil Cooler uses an SAE 45degree flare fitting with -8 (1/2", 12mm) Hose. Quote Link to comment Share on other sites More sharing options...
