Guest Looking for apt in Alb Ny Posted April 6, 2004 Share Posted April 6, 2004 Hey Gang Juan here. I know you haven't seem me much on the boards but I have been busy with my Z ,taking care of removing overstocked items, and bringing you some new items for 2004! here are your numbers for the rear brakes. 12.19x.81 rear brakes The hat will be identical to what I offer now but made with a total thickness of .792" Here is the brake down in numbers .272 is the hub surface material where the 4 lug holes are. .125 is the outside step needed for rotor centering .395 is the center counter bore with a 6" diameter. The bracket will not have any offset so that should be more than simple to machine from a .25 stock steel. With these numbers you get a .25" steel caliper bracket that works with Wilwood Superlite series caliper using a .81 rotor. Now you could shim the caliper in further and you could go a larger rear width rotor. Let me know if you guys are interested. I will come tomorrow with some more concrete prices. I will give you a reg price and offer and special first time run price! This is just a guess but it looks like around $279.95 or so. Yes its more than the front but The caliper bracket is larger and needs more machining. The hats will be more larger and needs that large center 6" counter bore to fit inside the the rear hub flange. If you notice my front hats I dont counterbore the centers. Only the spot for the bolts. This saves you money and keeps prices low. I will offer prepaid orders at a 20% discount! Im running this special for 3 weeks. As far as the front 5 lug hubs goes I haven't had enough interest for the hubs. I decided to go with he 5 lug brakes which was more priority. I will follow with the rear 5 Wilwood lug as well soon after. Thanks! Juan Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted April 7, 2004 Share Posted April 7, 2004 Juan, will the rear 5 lug setup be made to work with a 1.25" thick rotor, to match the front 5 lug setup you currently offer? That way you could use a caliper with 1.75" diameter pistons on the front and 1.38" diameter pistons on the rear and your rotors would be the same front and back. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
Savage42 Posted April 7, 2004 Share Posted April 7, 2004 You know I'm ready for a set!! (Just in time!!) Quote Link to comment Share on other sites More sharing options...
Guest Looking for apt in Alb Ny Posted April 7, 2004 Share Posted April 7, 2004 Ill be right back. I made some erros in my posting but they are simple fixes. Juan Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted April 7, 2004 Share Posted April 7, 2004 Hi Juan. Will there be an adaptor for the e-brake, and for the first run, will they be anodized? Thanks. -Eric Quote Link to comment Share on other sites More sharing options...
JMortensen Posted April 7, 2004 Share Posted April 7, 2004 Nice Juan!!! Let me just say that I have been collecting parts to set up my fronts and I can't wait to get them on the car. Maybe this weekend. Excellent parts, even better prices. At some point you'll definitely have more business from me when I buy a set of rears. Jon Quote Link to comment Share on other sites More sharing options...
Guest Looking for apt in Alb Ny Posted April 7, 2004 Share Posted April 7, 2004 Hi.. Does anyone have info on the leverage style ebrake caliper that Wilwood has? I went to their site but its not there. If that's still available an ebrake setup can be done using the same hats. The only thing needed would be a plate (which would be wickedly cool looking ) to mount the 2 calipers. This could take a while to build a rear eBrake setup because more time and research into the adaption would be needed. As far as the rear ebrake goes I will concentrate on the above mentioned setup with rear vents first. I really really appreciate the help and support for generating these parts. Honestly don't thank me. I just can't let an opportunity to help and knowing I have the machine facility minutes away from me. The more the interest the better the price. Mike, I dont see why you couldn't slap on a 1.25 rear rotor. Though it does seem a to be a large rotor for the rear. I'm not to argue on what people want to do. There should be enough clearance with the same hat but the brake bracket will be offset.This means more time and machining to make a bracket offset and strong. Sure I could make the hat a smaller thickness but its not the hat that should be modded but the bracket. This will help keep expense down still a bit and not have to machine a new expensive hat. You best net then is to make your own rar caliper bracket or mod the one which I will supply. I have a quote on the rear hats only. The cost of brackets and hardware will be added on to the hats shortly. The brackets I still have to get designed and quoted on. a pair of 4 lug rear hats so far is at $180!! This does not reflect the 5 lug cost. Ill try to see if I can squeeze in the 5 lug and keep the machine time down. So stay tune. Thanks again Juan oh I will make a post about this new style of caliper bracket I had designed not to long ago.It has to do with he 280zx Wilwood setup. I think you'll enjoy it. thanks Juan Quote Link to comment Share on other sites More sharing options...
Guest zigzac Posted April 8, 2004 Share Posted April 8, 2004 I'm interested in the rear set up. I am just about ready to purchase the calipers, rotors, pads, pedal assembly, and master cylinders for the front kit I bought from you on ebay about a month back. When you have a firm price, let me know. thanks Quote Link to comment Share on other sites More sharing options...
ToplessZ Posted April 10, 2004 Share Posted April 10, 2004 Im ready for the five lug rear setup. Got the front sitting here cant wait to get the rears. Then I can start wheel shopping Quote Link to comment Share on other sites More sharing options...
Guest 350zgto Posted April 19, 2004 Share Posted April 19, 2004 I want a set of 4 lugs to go with the fronts I got from you, but I do want an e-brake. I have been looking foward to this setup. Quote Link to comment Share on other sites More sharing options...
Guest Looking for apt in Alb Ny Posted April 23, 2004 Share Posted April 23, 2004 Hey Gang its me. I just wanted to inform you that I can do the rear in 5 lug for no extra charge! Please contact me JSK@jskinnovations.com for our special deal for the rears in 4 or 5 lug. we start in a few short weeks having these readily available. Because I only run limited stock at great prices the best thing you can do is reserve yours. Thank you Juan Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted April 23, 2004 Share Posted April 23, 2004 juan, i think ill get one of your 4 lug rear setup soon. i already have a disc brake setup on the rear on the green Z but i would love to have a matching setup of yours to match the fronts. plus i can always take the rear setup i have now and put them on the blue Z.. well ill talk to you on AOL. thanks man. mike Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted April 26, 2004 Share Posted April 26, 2004 Hi Juan. I'm interested in the rear 4 lug setup also. Any word on how much the set will cost (anodized black hats, brackets, and hardware)? Also, when do you think an e-brake adapter will be completed? Will the rear setup clear 15" rims just like the front setup? Thanks Juan. Looking forward to getting another one of your products! -Eric Quote Link to comment Share on other sites More sharing options...
Guest Looking for apt in Alb Ny Posted April 26, 2004 Share Posted April 26, 2004 Hi. I ve been clearing out alot of old stock items to get rolling with some dough and preorders help as well. I am offerring a 20% off deal (I'm not kidding either) on the rear Wilwood setup. Offer Good until end of April. Ill also be prmoting on ebay but if you see this you can contact me directly through my email. Here is a photo of my setup inside a 15 inch enkei wheel. you need 12.6" diameter clearance. Thanks again Juan Quote Link to comment Share on other sites More sharing options...
Mikelly Posted April 27, 2004 Share Posted April 27, 2004 Juan, You've got e-mail... Also, Someone mentioned the little e-brake adapter that Wilwood sells... BLKMGK has the setup on his car and HATES it... Says they drag constantly... Just an FYI! mike 8) Quote Link to comment Share on other sites More sharing options...
Guest Looking for apt in Alb Ny Posted May 5, 2004 Share Posted May 5, 2004 I just wanted to inform that I will be underway with the machining of the rear 4 n 5 lug Wilwood setup and new Billet Fuel Rails shortly. Expect about early to mid June for completion. I will like before have photos of the development for your enjoyment. Thank you again ever so much to allow me the opportunity. Juan Quote Link to comment Share on other sites More sharing options...
Guest Looking for apt in Alb Ny Posted June 7, 2004 Share Posted June 7, 2004 If any of you are interested in viewing the rear bracket CAD work please visit http://www.jskinnovations.com/Wilwood4.htm . They should be done shortly. I appreciate your patience with me in getting this put together. thanks Juan Quote Link to comment Share on other sites More sharing options...
Bluto Posted June 7, 2004 Share Posted June 7, 2004 Is that R14? yuck... you need 2004.. hehe Quote Link to comment Share on other sites More sharing options...
Guest zigzac Posted June 26, 2004 Share Posted June 26, 2004 Hi Juan, I took a look at your site and noticed it said the rear kits were now available, does that mean those of us who preordered a kit should be expecting them in the mail soon? -Zac Quote Link to comment Share on other sites More sharing options...
Drftn280zxt Posted June 27, 2004 Share Posted June 27, 2004 Juan, Hopefully I can eventually use my three years of training on CAD, and 3DVIS. These were probably the two most valuable classes I took in high school. I just graduated this year. I'd post the animation I made this year that I did in VIS but my teacher forgot to burn all of our work to CD's and give them to us like he said he would. My skills with CAD and VIS earned me the title for which I was awarded for, Drafting student of the year, out of like 300 drafting students. (my high school was big, 3000+ students(I live in Las Vegas what do you expect)). (I'm not asking for a job just telling you meaningless info for the heck of it) Sorry to get off subject but in the future I'll be considering a five lug conversion with bigger (12"or>) brakes and four pot calipers, along with coilovers when I find'em for my 280ZX. With the quality I see in your products your at the top of the list as far as I'm concerned. Here's a weird question. Are CNC machines capable of milling and L28 engine block (bored to 3.1L) out of a solid Aluminum block?(I not asking you to do it, I'm just curious to know for future reference) Quote Link to comment Share on other sites More sharing options...
