namz7791 Posted April 19, 2004 Share Posted April 19, 2004 I was able to use my press to get the spindle pins out of the rear control arms. I tried to do this to the old bushings also and the only thing that would give was the control arm itself Luckily, I have a spare but only one - so what is the trick to get the actual bushings out for replacement with the prothane polyurethane bushings? I vaguely remember some one burning the bushings out of a moustache bar - is this the best way or should I be cutting them in pieces? Please help before I have to look for yet another control arm Thanks for the help and this is a 77 280Z. Quote Link to comment Share on other sites More sharing options...
Tim240z Posted April 19, 2004 Share Posted April 19, 2004 From what I remember (it's been a few years), you can burn out the rubber, then, with a hacksaw, cut out a strip of the sleeve, then with a screwdriver, or thin chisel, knock out the sleeve by collapsing it in on itself at the cut area. Tim Quote Link to comment Share on other sites More sharing options...
CruxGNZ Posted April 19, 2004 Share Posted April 19, 2004 I tried to do this to the old bushings also and the only thing that would give was the control arm itself Wow, one would think the rubber would give before the control arm. Were you trying to press out the sleeve? I know Energy Suspension bushings require you to remove all the original bushing shells except the two from the mustache bar, but does the prothane kit require this as well? If so, your safe bet would be to do like Tim said, and cut the shell instead of trying to press them out. I found it easy to make two cuts in the shell with a hack saw about 1/4" from each other and then pry out the shell with a standard screwdriver. Piece of cake !M! Quote Link to comment Share on other sites More sharing options...
namz7791 Posted April 19, 2004 Author Share Posted April 19, 2004 Thanks for the input! Yeah, I never thought that the arm would bend first either Quote Link to comment Share on other sites More sharing options...
Forrest Posted April 19, 2004 Share Posted April 19, 2004 There is no need to burn out the rubber. You can heat the outside with a torch and pull the rubber out with vicegrips. It is much cleaner. Quote Link to comment Share on other sites More sharing options...
BillZ260 Posted April 19, 2004 Share Posted April 19, 2004 There are many posts on this, I know cause i posted many of them wehn I was working on my suspension. Do an advanced search on bushings and you will find several solutions. Quote Link to comment Share on other sites More sharing options...
