sims76 Posted May 21, 2004 Share Posted May 21, 2004 ...Should be about another 2-3 weeks without rushing. Here is an old post where you all helped me choose a turbo. I went with a T3/T04E 50 Trim from James T. http://hybridz.org/nuke/index.php?name=PNphpBB2&file=viewtopic&t=32488&highlight= I welded the weights and plate in my distributor so they don't move the magnetic pickups anymore. I turned the distributor by hand and the coil was crackling like crazy every time a tooth on the reluctor went by the magnetic pickup. I'm using a HEI module between the pickup in the distributor and the MSnS box as a filter/amplifier. MSD6A will finally deliver the spark when it gets the trigger from MSnS. Hopefully, the trigger is still accurate. I replaced a piston that had damage from what looked like a foreign body. James T tapped my oil pan. P90 head is on. New timing chain & sprokets. Pallnet O-ring fuel rail. Boost gauge. The list goes on. I've been busy and I'm starting to get excited. Does anyone know where I can get OVAL injector connectors to fit the 92 Supra Turbo Injectors I'm using? I have had no luck finding them. This is the only part I need to finish this project. Thanks! Sims Quote Link to comment Share on other sites More sharing options...
mobythevan Posted May 21, 2004 Share Posted May 21, 2004 Sounds good. I am curious to see if you have any troubles with using the MSD. Let us know when its running. Quote Link to comment Share on other sites More sharing options...
Forrest Posted May 21, 2004 Share Posted May 21, 2004 Me too. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 22, 2004 Share Posted May 22, 2004 Oh, Forrest, quit complaining! You want troubles: read the sticky for my latest! Hope you guys keep having good luck. I know I'm not. Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted May 22, 2004 Share Posted May 22, 2004 I picked up injector connectors from the local salvage yard. I just cut them off the wiring harness and spliced them in. Good luck w/ the MSnS install... Quote Link to comment Share on other sites More sharing options...
Guest bastaad525 Posted May 23, 2004 Share Posted May 23, 2004 definately very interested to see how MSD works with MS as well... been watching all your guys' MS posts like a hawk.... I REALLY want to see you guys all come thru with this and get it working right Quote Link to comment Share on other sites More sharing options...
