CruxGNZ Posted August 19, 2004 Share Posted August 19, 2004 While looking for information on relocating a master cylinder in another post, I ran across this in a Yahoo search: http://www.cardomain.com/id/revac Not only is this car a pretty cool hybrid, but click on his Supra half shaft installation. Very interesting. Is the owner a member here? !M! Quote Link to comment Share on other sites More sharing options...
john kosmatka Posted August 19, 2004 Share Posted August 19, 2004 Nice find Mat, that car is really clean looking too. Good info and a nice diagram too, Ill have to look into that If I dont use my R230. John Quote Link to comment Share on other sites More sharing options...
stony Posted August 19, 2004 Share Posted August 19, 2004 too bad hs is still using stock stub shafts. I amagine about the time i finish my solid rear install someone will come up with a bullet proof stub shaft upgrade Quote Link to comment Share on other sites More sharing options...
blueovalz Posted August 19, 2004 Share Posted August 19, 2004 Now to investigate the strength and design of the shafts. Thanks. Quote Link to comment Share on other sites More sharing options...
Sparky Posted August 19, 2004 Share Posted August 19, 2004 Woah! that looks incredibly easy and cheap to do. I wonder What kind of power those shafts can take? if he's not a member he needs to be ASAP! Quote Link to comment Share on other sites More sharing options...
enigma Posted June 6, 2005 Share Posted June 6, 2005 Hey All!! Yes, this is my website you have found here about putting Supra Halfshafts on a 280z. This is actually the weblink to the conversion: I havn't been on this site in ages, and they deleted my original post about this, and changed all my other posts to "Anonymous". Guess I should come over here more often. Had to create a new profile. My car that has the Supra shafts on it is a '75 with a Ford 347 and a T5 in it. I am guessing it's about 350hp, and I have not had a problem yet with the shafts after about 20k mi. I run big 275/40/17's on the back, too. I researched Supra shafts on a Supra forum, and I did not find anyone of those guys complaining that they broke a shaft. When I did the conversion, I did it quick and easy in my backyard with a stickwelder. If I had to do it again, I would make the adapter plates with a special hole cut in them to fit over (not on top like you see in the pics) the Z flanges, weld them on, then have the mounting surfaces retrued on a lathe (to correct the warp of welding), and then have the pilot diameters cut as a last step. This would also leave the shafts about 1/2-3/8" longer which is preferable. I am also the guy who originally came up with the idea of putting a Neal pulling slave cylinder to operate the clutch on a Ford-T5 combo. This is my car, but I have taken off the injecton and put a carb back on since I posted this: http://www.cardomain.com/ride/543729 Enigma Quote Link to comment Share on other sites More sharing options...
Venture Posted June 8, 2005 Share Posted June 8, 2005 I really dig your car, and I am very interested in doing this swap. I already have the plates cut out. I cut the perimiter and the holes out of a piece of steel a little thicker than called for on your blue print. Very detailed prints I might add. I plan on welding them up and finishing them on a lathe as you suggested. What do you mean by leaving the shafts 1/2-3/4" longer? Do the supra shafts extend and contract like the stock half shafts? Did you have the CV shafts balanced. Have you had any problems with vibration? Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted May 30, 2006 Share Posted May 30, 2006 I'd like to know if anybody else has done this... i looked up the price of the CV axle from the toyota they are 65 bucks with a 25 dollar core charge for brand new with a 7 yr 70,000 mile warranty. so 130 bucks plus 50 in core charge and some machining cost... seems like this would be the cheapest/best solution. -Ed Quote Link to comment Share on other sites More sharing options...
Nismo280zEd Posted June 10, 2006 Share Posted June 10, 2006 just want to bump this thread as i'm trying to get the brackets machined to do this conversion. Quote Link to comment Share on other sites More sharing options...
