iflyfast1 Posted August 27, 2004 Share Posted August 27, 2004 Does anybody that's using John's mounts have the part numbers for the upper and lower radiator hoses? I'm going to use aftermarket gauges so I don't want to buy John's fluids kit. Thanks. Tom Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted August 28, 2004 Share Posted August 28, 2004 HEY TOM!! My hoses didn't come with part numbers on them. They are good quality, most likely Gates or Goodyear. Call John. As for the vital fluids kit. The rad hoses will work with, Four row datsun (heavy and expensive) with camaro fans or the JTR radiator and mounting brackets and a 3.8l 2 speed taurus fan.(what i have). I'm not sure about the Griffin rad and Taurus fan. I used the coolant adapter with the stock Datsun sending unit. The oil pressure adapter won't work if you are using the same headers as mine (Sanderson made by Boyd). The headers dump right where the sending unit would be. Options??? You will need to get an adapter to go in where the oem camaro sender is. It is a 16 m.m. X 1.5 thread pitch. P.M. MAS280 for the company that makes it or what I'm gonna do is get an oil drain plug the same size, drill a hole and tap it to the nissan sending unit. I hadto buy 90 degree bent heater hose to atatch to my core. Soo anyways Get the hose numbers, o.p.s. adapter (won't come with the gauge). I'm sure there is another spot for coolant except the big plug where John's goes JOEY P.S. I'll get a hold of you monday or tuesday at latest to check out car after work. And yes I'll get a hold of Mike also! Quote Link to comment Share on other sites More sharing options...
MikeJTR Posted August 29, 2004 Share Posted August 29, 2004 You should be able to use Camaro LS1 radiator hoses that are shortened and spliced together. If you are using the JTR-Camaro style radiator, you will need a "Tee" to splice the vent tube into the upper radiator hose. LS1 Z is using a JTR radiator and upper radiator hose tee on his car. JTR has a variety of hose splicers and hose tees. While not shown on the website, JTR has 1-5/16" hose splicers and hose tees, which fit the LS1 hoses better than the 1-1/4" or 1-3/8" splicers and tees. See the attached links: http://www.jagsthatrun.com/Pages/Parts_TPI-TBI_Brass-Tees.html http://www.jagsthatrun.com/Pages/Parts_TPI-TBI_HoseSplice.html Quote Link to comment Share on other sites More sharing options...
mas28O Posted August 29, 2004 Share Posted August 29, 2004 Quote Link to comment Share on other sites More sharing options...
iflyfast1 Posted August 30, 2004 Author Share Posted August 30, 2004 Quote The oil pressure adapter won't work if you are using the same headers as mine (Sanderson made by Boyd). The headers dump right where the sending unit would be. Joey, Street and Performance makes an adapter to clear the headers that might work. http://www.hotrodlane.cc Mike, I purchased your JTR radiator a while back. It looks like it will work with the stock LS1 Camaro fans if I don't use the trans cooler outlets which I don't need. (I'm using a T56) Do you sell caps or plugs to cap these outlets off? Quote P.S. I'll get a hold of you monday or tuesday at latest to check out car after work. And yes I'll get a hold of Mike also! Joey I'm looking forward to hear what that beast sounds like! Tom Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted December 20, 2015 Share Posted December 20, 2015 I'm digging this post up from the grave, because I am trying to identify a upper and lower radiator hose that will work with: LS Series Gen 3/4 water pump Champion 3-row Radiator Does anyone have part numbers or store you can get hoses that are the correct length? The lower is proving to be quite difficult. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted December 20, 2015 Share Posted December 20, 2015 It may prove easier to put a different lower tube on the bottom radiator tank. Take a look at how that might change your options. You can buy radiator necks from Speedwaymotors.com that you can have tig welded on in place of the Champion tube which was made to mimic the radiator needed for a L6. Another thing that might be helpful is a straight water pump outlet. I think there are a couple places that make those now. Quote Link to comment Share on other sites More sharing options...
socorob Posted December 22, 2015 Share Posted December 22, 2015 There's another thread on here with the part numbers. That's the exact setup I have and I got my part numbers from that thread. Quote Link to comment Share on other sites More sharing options...
socorob Posted December 22, 2015 Share Posted December 22, 2015 22478 lower and 21588 upper are some gates numbers I found, but double check them. Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted December 22, 2015 Share Posted December 22, 2015 Keith, I definitely liked the idea of what you did with your rad. I don't know if I could muster cutting up a good champion radiator for that. Right now I have the top hose figured out. I more than likely will take two hoses, cut them, and use a coupler to fit them to one. Socorob, I've looked for a while now and am stuggling to find the thread you are referring to. If you have a link that would be great, otherwise I will just keep searching. Quote Link to comment Share on other sites More sharing options...
auxilary Posted December 25, 2015 Share Posted December 25, 2015 (edited) I purchased Gates 22625 and 22625 based on research here, but I don't yet have an oem style radiator to test them out with Edited December 30, 2015 by auxilary Quote Link to comment Share on other sites More sharing options...
Stock Car Mafia Posted December 29, 2015 Share Posted December 29, 2015 Auxilary, let us know if they work! I didn't see scorob's post on the part numbers but people like him and Keith make this place a great resource for guys like us! Quote Link to comment Share on other sites More sharing options...
