What engine compression ratio?
Guest Magic
Hi Guys
Out here in Australia we didnt get the P90 turbo in the L28. But I have managed to source one and am looking to hook it up to the following setup in my L28.
Intercooled
T3/TO4E turbo
370cc injectors
Fully programable Engine Management
Stock turbo inlet / exhaust manifolds port matched & ceramic coated.
57mm throttle body
My question is, what is your experiance / recomendation with engine compression ratios for the P90 head? Im rebuilding the motor so changing the compression ratio is an option.
At the moment im thinking of aiming for a target of 14psi (250-300rwhp?) & I want to get the engine compression ratio as high as possible to keep things efficient and punchy low down for a street application.
Your thoughts and experiances would be really appreciated in helping me decide what I will do.
Thanks in advance.
Magic
You can change the compression by shaving the head, enlarging the bore & pistons, changing the brand/thickness of your headgasket and also by changing the "height" or contruction (dished or flat) of the piston to some degree. If you shave the head you will need shims to compensate the amount you have shaved off.
Most engine builders can work out what is required to change the CR if you know what the standard engine dimentions and compression ratio is.
Back to the original post,
Anyone else out there raised the compression of their P90 and gone into 14psi+ boost territory?
I've run an L26 flat top with N42 head, L28 with N42, and L28 with P90, all turbo'd. What little I lost in off boost torque didn't matter with the P90 as I could make more on boost power :twisted: . You could use a 1mm MHG HG, stock is 1.2/ .050" and take just enough off to clean the head and get it straight. I wouldn't run anything but the factory dished turbo pistons or forged, All N/A pistons are weaker. 14 psi / 8.0:1 will make less HP than 17 psi / 7.4:1 but both have the same compression ration under boost. If you cut the head and don't use shims it retards the timing, just gives a little more top end. I have never shimmed the cam towers and have cut .120" off of an E88 on an N/A motor. Here's a couple of links
http://not2fast.wryday.com/turbo/compression/compression.shtml
http://www.turbofast.com.au/javacalc.html
I'm running P79 flattops with a P90 head and it works fine, with a static CR of 8.8:1. I'm running about 10 psi w/ an NPR IC in the AZ heat, and it doesn't seem to mind with the Z31 ECCS. I like having the extra bottom end for street driving. Of course, I can't run as much boost as a 7.4:1 CR motor, but right now, my boost limit is dictated by the ECU/injector limitations, and not by the CR.
The only difference I can see between a dished turbo piston, and a flattop P79 piston is the dish. The rings and ring lands are the same size. It's the pre-81 NA pistons that are the weaker ones. Since you do have access to high octane fuel, and you're using programmable EFI, I think it's safe to bump up the static CR, especially since your HP goals are modest.
Sean
73 240Z, L28ET, T3/T04E, NPR IC, Z31 ECCS
Ok cool.
I feel a lot happier with upping the compression now. I took my motor out yesterday and have started to strip it down. Will keep you updated, any one elses experiance with raising the CR is appreciated :-D
