love-my-V8-280Z Posted September 13, 2004 Share Posted September 13, 2004 This post probably should be posted in fuel delivery but it is for a V8 and I need the hits... Anyway I have searched the site and there is not much on external fuel pumps. We need a large posting for the future.. I have read that several people are not happy with the Holley because they are so loud.. And I think the Mallory 110 maybe quite but the one posting I found it was said that it failed with only a couple of hours on it.... So would anyone that is using a electric external fuel pump please let us know if its quite and if it has been dependable.. Thanks Quote Link to comment Share on other sites More sharing options...
Tim240z Posted September 13, 2004 Share Posted September 13, 2004 I am using the MSD inline pump. It's only about $80 and has enough flow and pressure for the LT1. I found it very noisy, but then after I installed the surge tank with a secondary low pressure feed pump, the MSD pump got very quiet....I can barely hear it now. I think that actually feeding the MSD pump with a bit of pressure at the inlet makes all the difference, it doesn't have to work very hard to 'pull' fuel. http://store.summitracing.com/partdetail.asp?part=MSD-2225&Ntt=msd fuel pump&Ntk=KeywordSearch&N=110&PartSearchFlag= Quote Link to comment Share on other sites More sharing options...
buZy Posted September 13, 2004 Share Posted September 13, 2004 Hmmm. I'm keeping my eyes on this thread. Maybe I'll try one of those. I'm the guy with the failed Malloy 110 comp pump. But I would also like to see something that would work more with a typical carburated 327 as well. Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted September 13, 2004 Share Posted September 13, 2004 I have the Napa aftermarket replacement for the Ford Van with the 360 FI motor. I mounted it with the rubber covered hose clampy like things (technical term) over the rubber sleave that comes with it to a bracket that I again mounted with a chunk of rubber to the body. I've only heard the fuel pump once (other than the standard whine of it priming before start-up) and that was during a vigorous climb up a curvy mountain road. It was $120. Two years later when I did the LT1/Tomahawk swap I went to get the same pump from Napa and they said it was discontinued but a replacement was available from Holley. Guess what? Same pump in a different box. Something special about the new cardboard box I guess because the "Holley" pump was $40 more. Mounted it the same way in the Tomahawk as in my car and again no noise. Tomahawk is a roadster though, so it may be noisier but I can't hear it. Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted September 13, 2004 Author Share Posted September 13, 2004 Dan, Can you tell me more, what year ford, or better yet what kind of a holley was it? was it generic or made to fit the ford??? Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted September 13, 2004 Share Posted September 13, 2004 Dan' date=' Can you tell me more, what year ford, or better yet what kind of a holley was it? was it generic or made to fit the ford???[/quote'] Urrrg... I was afraid you would ask that. I never did have a direct application. Our Napa has some good counter guys. When I explained it came from a late model full size Ford van and it was an external pump for the 360 FI motor they found it right away. I don't think there are very many V8 FI motors that use external pumps. 360 Ford? No, that can't be right. Must be a 351. Was it a 460? Oh great, this isn't helping. Sorry. Give me a little time. I'll try to find a receipt. Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted September 13, 2004 Share Posted September 13, 2004 My 86 F100 302 had one mounted on the inside of the frame rail. Easy to get to and change. I changed over to a carbed system and did the tank pickup swap, I can't remember if there was a pump inside the tank or not. Anyway, I went to napa and got an universal electric pump and used it. It ran fine until I hooked my 5th wheel to it. 25mph up a slight incline. It was starving for gas. Just make sure you get a good one. Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted September 13, 2004 Author Share Posted September 13, 2004 Went to my local parts store and told them my problem... They too knew the Holleys were loud.. But when I told "John" how much pressure I needed he said I have just the pump! Dan, you will like this, its from a 87-88 F150 with the 5.8.. He said they are very quite... max output is 50 GPM. So anyway it will be several months before I can really run it to listen but what the heck $90.00. Anyone think I will have problems with the GPM?? I'm kind of planing on the LT4 upgrade some winter after my beauty is on the road running.. Terry Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted September 14, 2004 Share Posted September 14, 2004 I use a Carter CRT-P4594 that I bought from Summit http://store.summitracing.com/ The bracket has rubber grommets and the pump doesn't make much noise. I mounted it to the outside of the spare tire well using stove bolts and put some self adhesive rubber based sound proofing pads on both sides. You can hear the pump running but it is not very loud. Actually, once the engine is running you don't notice it at all. BTW, it's only $59.95. Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted September 14, 2004 Author Share Posted September 14, 2004 Speed Racer, what motor are you feeding? A carbed or Fuel Injected? Thanks Quote Link to comment Share on other sites More sharing options...
nullbound Posted September 14, 2004 Share Posted September 14, 2004 im also using a carter and it works really well. i mounted mine on my fuel cell box with the included rubber grommets. as stated above, when the engine is running, you can't hear it. mine's a carb'd 377. Quote Link to comment Share on other sites More sharing options...
SpeedRacer Posted September 14, 2004 Share Posted September 14, 2004 It's an old 365 HP 327 SBC with Tri-Power Quote Link to comment Share on other sites More sharing options...
Sleeper-Z Posted September 15, 2004 Share Posted September 15, 2004 using a mallory fuel pump here with no problems 1+year. you can hear it whir before you turn on the motor, but after, the rumbling sort of distorts eerything between a 30 yard radius. ps. i believe i have the 140... Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted September 15, 2004 Author Share Posted September 15, 2004 Thanks guys! Love that pic Speed Racer, I would be polishing that motor after every trip! Quote Link to comment Share on other sites More sharing options...
love-my-V8-280Z Posted September 21, 2004 Author Share Posted September 21, 2004 WEll the new fuel pump is a JOKE!!!!!!!!!! Its so loud I will have to run open headers and I will probably still hear it! It put me in a crappy mood!!! $100 waisted! Quote Link to comment Share on other sites More sharing options...
nullbound Posted September 21, 2004 Share Posted September 21, 2004 which one did you get and how did you mount it? an electric fuel pump is going to make noise.... Quote Link to comment Share on other sites More sharing options...
PaulR Posted September 21, 2004 Share Posted September 21, 2004 When I first installed a Holley "red" pump, it was real loud. I then mounted it to a bracket and mounted the bracket to the chassis using these isolators from McMaster Carr. Made a big difference (but I can still hear it) http://www.mcmaster.com/asp/enter.asp?pagenum=1218 Quote Link to comment Share on other sites More sharing options...
nullbound Posted September 21, 2004 Share Posted September 21, 2004 that's basically my point. you are going to hear it... even running my car now with open headers (and it is seriously loud this way), i can hear the fuel pump. the way you mount it has a lot to do with the amount of noise that gets transferred inside the car. if it's mounted solidly to the car (even with the rubber grommets that usually come with the mounting bracket... not so good on noise reduction), it will be noisier than mounting it with something like paul pointed out. Quote Link to comment Share on other sites More sharing options...
Pyro Posted September 21, 2004 Share Posted September 21, 2004 I had good luck with my Mallory pumps. In fact, I just bought a comp110 last month and I'm using it as a feeder pump to my EFI pump on my turbo Z. However, you should run a filter before the pump. I also have a Mallory comp140 on my V8 Z and it has been work well for a few years. FYI, you need a low pressure pump, not an EFI pump. Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted September 23, 2004 Share Posted September 23, 2004 I'm using John's pump. By looking at pictures, here, and on the web, I believe it's the Wilber255. Mounted in the same spot as the stock 280z pump. The pump is very quiet. bearly hear it with key on engine off. No surge tank or pre-pump JOEY Quote Link to comment Share on other sites More sharing options...
