Crazy idea about how to fix a rusty hub?!?!
I bought a couple of 280 hubs from Juan @ JSK when I bought his brake kit. Just got into them and after cleaning off the grease I can only say holy crap are they rusty. I realize that I can get a couple more hubs cheap if need be, but I've already got these here, hence the idea.
Is it possible to turn the wheel mounting flange on a hub like a rotor?
I'm trying to think back to my wrenching days and I'm thinking that a standard brake lathe might not do it. I started to just sand the surface and there are some pretty big pits. I'm sure once the rust was gone it would probably only take .010 or so to get them perfectly clean and straight again.
So what do you all think? Dumb idea? Not worth it?
Might be kinda tough to put in the jaws. Maybe there's a machinist on here who could pipe in. I'm sure it could be done. There are centerbores on both ends of the stub axle for fixturing. It's not like you're gonna be cutting a bearing land (correct terminology?) and have to keep a close eye on TIR.
  • 4 years later...
On my hubs they looked like they had sat in a junkyard for years. They were really heavily pitted. I just ended up buying new ones from zbarn.com. I still have the junky ones, but cleaning them isn't going to cut it. They'd probably need .020" taken off to make them flat again.
