Hugh Posted September 22, 2004 Share Posted September 22, 2004 Stock Sylvania sealed beam first, then Raybrig H4 6024 conversion lights with blue tinted lenses. (you can use normal bulbs and still get the while light effect) These beams are designed for right hand drive, so they throw a bit of light into the oncoming traffic's faces. Pointing them down can solve this, though. (although sacrificing a bit of the light.) My review: Freaking Bright!! I still have the stock wiring on my 240z's headlights... these are ten times brighter than the stock crap. Quote Link to comment Share on other sites More sharing options...
Guest ON3GO Posted September 22, 2004 Share Posted September 22, 2004 i think they look slick! post some night pics with them on. nice Z too.. i had those same wheels on my green car when i got it.. clean car! mike Quote Link to comment Share on other sites More sharing options...
NZeder Posted September 22, 2004 Share Posted September 22, 2004 Gotta get some of those....RHD you say....very cool for those of us that do have RHD and drive on the left side of the road. Now to see if I can get them in NZ. Quote Link to comment Share on other sites More sharing options...
Hugh Posted September 23, 2004 Author Share Posted September 23, 2004 I bought mine in Japan when I lived there. They used to be on my wife's Miata (Eunos Roadster or MX5 over there) Quote Link to comment Share on other sites More sharing options...
Mikelly Posted September 23, 2004 Share Posted September 23, 2004 YUp. Bought some of these last year for my project... Glad they weren't a waste... Mike 8) Quote Link to comment Share on other sites More sharing options...
Guest 2slo4u Posted September 23, 2004 Share Posted September 23, 2004 Those lenses look cool, and so does the car. Eastwood sells street legal H4 conversion headlights for our cars for really cheap. I think about $50 for the pair, they even include bulbs and have nice warranty. (I got mine from Sherco in exchange for some faulty injectors or I would have bought them from Eastwood. They are ultra bright, ask Mike. ) 81zxturbo 95slobaru Quote Link to comment Share on other sites More sharing options...
hanomon Posted September 23, 2004 Share Posted September 23, 2004 Anybody hear of HID-Xenon light conversions at iguanamotors.com? I was considering this type of upgrade. Quote Link to comment Share on other sites More sharing options...
Hugh Posted September 23, 2004 Author Share Posted September 23, 2004 Make sure they're not the same ones selling for like $10 on ebay. If so.. then buy them on Ebay for $10 and save cash. I'm pretty sure the ones on ebay are the same ones I bought a few years ago when they were $50... they worked fine, but water go into one. I resealed them and never had a problem. (and they were loads brighter than stock) Quote Link to comment Share on other sites More sharing options...
georgiaz Posted September 24, 2004 Share Posted September 24, 2004 Question. Did you have to use relays in order to use these headlights or is the wiring stock? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted September 24, 2004 Share Posted September 24, 2004 You don't have to use relays but, they sure do help. Quote Link to comment Share on other sites More sharing options...
Guest 2slo4u Posted September 24, 2004 Share Posted September 24, 2004 I installed relays for mine and they drew so much current I had to use a 30 amp fuse. They would blow the 25 amp fuse on low beam! BTW, be careful when shopping for "HID" headlamp setups. Most of them are not actually HID (High Intensity Discharge) and they use normal filaments. HID setups have ballasts to modify the voltage to a very high level. I haven't seen an actual new HID setup under about $400. 81zxturbo 95slobaru Quote Link to comment Share on other sites More sharing options...
Hugh Posted September 24, 2004 Author Share Posted September 24, 2004 Quote My review: Freaking Bright!! I still have the stock wiring on my 240z's headlights... these are ten times brighter than the stock crap. Still stock. I'm going to install a relay setup eventually, though. The relay kit is not going to make your lights draw higher current and blow fuses... it allows them to draw the current they want. Right now its bottlenecking through crappy old wires. Once you put in relays with fresh heavier gauge power wires, full current capacity of the lights can be realized. What sort of bulbs do you have that draw 30 amps, anyway? Just curious. Japanese bulbs always display the wattage (actual and displayed) on the box. I bought 55/60 watt bulbs. (i was afraid of the 100/130 bulbs on this old system. However, with relays in, I will run the brighter ones most likely. These housings come with Raybrig bulbs originally, but one was blown from when they were on my wife's Miata. I put in APC bulbs. ($24 from Kragen) Quote Link to comment Share on other sites More sharing options...
Guest 2slo4u Posted September 24, 2004 Share Posted September 24, 2004 I know the relays don't cause the current draw. The bulbs drew more than 25 amperes AFTER installing them with relays (which are necessary on my 81zx to keep from melting the stock wires) so I had to use a 30 ampere fuse. The wire supplying them is ten guage which is required for a 200 watt draw. They are 90/110 watt bulbs I believe. Ridiculously bright. When driving, other people's lights look yellow on the road. Still haven't gotten any flashes either from other people so I guess they are aimed just right. 81zxturbo 95slobaru Quote Link to comment Share on other sites More sharing options...
Hugh Posted September 25, 2004 Author Share Posted September 25, 2004 heh heh, yeah... thats a lot of watts. Quote Link to comment Share on other sites More sharing options...
pecx Posted August 31, 2011 Share Posted August 31, 2011 (edited) If anybody want these Raybrig H4 housing please let me know. I have some for sale. Available in blue or clear. Edited August 31, 2011 by pecx Quote Link to comment Share on other sites More sharing options...
