Jtr Ls-1 Pics
mark
I thought about it, but i sold the LT1 for the same reason I don't want an LS1....I want to build the motor myself with my own choice of parts and combinations, not something the factory has done....I did think long and hard about it though.....
I got my set last night. I agree on the coating. The welds on mine could have been cleaned up a little better before they coated it though.
If you use those headers on other applications then you have to move the engine mount on the passenger side forward like the johns car kit. The header goes right through where the stock mount is at.
  • 4 weeks later...
Guest ALL UC2
why cant you build a ls1?? have you never checked out ls1.com, ls1tech.com, or ls2.com??? they have just about anything you want to build one. everything you can get for a gen 1 motor you can get for a ls1
  Quote
Forecast for Danville' date=' Va, Sat Feb 12: 27 deg.
You guys take your long underwear, have a good time and bring the car back looking like it did when you took it!
I'll be in therapy..........
John[/quote']
The first run session will be a give away with a cold car a cold track and cold tires. Not to mention a cold 44 year old body. I'm sure by lunch it will be near 50. I have the thermals packed and thinking about bringing my propane heater.
How is the therapy going? Can't be better than a track day but you do need to work out your anger issues, your so up tight. (where are those smiliey things)
Mike,
looking foward to meeting you and seeing some other Z's on the track besides the tail lights of John's.
