ANY ONE HAVE A 255 (or bigger) FUEL PUMP FS?
white86turboz
While we're on the subject of Walbro pumps, I am going to replace my dead pump with a Walbro and I'm curious to know if the Walbro is going to increase fuel pressure above stock from the old pump. (ZXT pump) I don't have an adjustable pressure regulator yet (saving up for it). Do I need to adjust the AFM settings aka will the Walbro make me run any richer at idle and cruising if it does increase fuel pressure? Thanks.
John 82ZXT
While we're on the subject of Walbro pumps' date=' I am going to replace my dead pump with a Walbro and I'm curious to know if the Walbro is going to increase fuel pressure above stock from the old pump. (ZXT pump) I don't have an adjustable pressure regulator yet (saving up for it). Do I need to adjust the AFM settings aka will the Walbro make me run any richer at idle and cruising if it does increase fuel pressure? Thanks.
John 82ZXT[/quote']
I'm doing just fine with the stock regulator and a Walboro 255 internal pump.
It's only the pump, no screen or wire plug. I would spend the extra $20 and get the install kit to make it easier to install. I know 87-88 300ZX turbos have intank pumps, I would think they are all the same but not 100% sure.
You don't need an adjustable or aftermarket regulator.
most newer cars have the pump hanging off of the fuel sender with a sock on the bottem to strain the fuel.pump and tank are installed as an assembly -its faster at the factory .hoses have snap on connectors and 1 plug for the wiring.older cars like 75 up z with efi had an EXTERNAL pump mounted to the body of the car with a hose feeding the pump.pump had to be mounted low so it would pick up fuel.i am installing a walbro gsl392 external inline pump on my 77 z.the threads on the walbro pump require you to buy adaptor fittings.i am running a 12mm hose barb on the inlet and a adaptor for 6an hose on the outlet side.i am building a custom fuel rail with an fittings.fuel system pressure side will be 6an or equal to 3/8 line.i have heard 5/16 line is good for up to 400hp at 40 psi so the 6an should not ever be maxed out with a l28 motor.
