jaime240z Posted February 25, 2005 Share Posted February 25, 2005 OK I tried searching on this but I still have a question. I just got a Griffin 24x19 universal GM style rad. I'm trying to get it mounted but I'm having a hard time finding the rubber insulator pads for the upper and lower radiator mounts. I've tried all the local auto parts stores. I would like to use an oem style piece instead of rubber tubing or hoses as someone suggested in other posts. I'm trying to keep the install as "oem" or sanitary as possible so I'm hoping someone has a part number or source for some nice mounting pads. Thanks. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted February 25, 2005 Author Share Posted February 25, 2005 oops. I realize this is more of a "cooling" question but I figures alot of SBC guys are using this radiator. Thanks Quote Link to comment Share on other sites More sharing options...
Guest 77vegasz Posted February 26, 2005 Share Posted February 26, 2005 your local junk yard will have tons of them. Jon Quote Link to comment Share on other sites More sharing options...
80LS1T Posted February 26, 2005 Share Posted February 26, 2005 I would be interested in this too if you find some part numbers for some nice mounts. I need to mount mine different because I kind of had it solid mounted which isnt a good thing for an alluminum radiator. Guy Quote Link to comment Share on other sites More sharing options...
buZy Posted February 26, 2005 Share Posted February 26, 2005 I had this problem and had to make my own out of billet alum and rubber mountings. These cars are custom but thats whats worth it in the end. I'd post a pic but I can't as of now. Just remember NOT to mount it directly to your frame or it will crack and leak. Yea the junk yard might work, worth a shot at least. Good luck! Quote Link to comment Share on other sites More sharing options...
jaime240z Posted February 26, 2005 Author Share Posted February 26, 2005 Hey thanks guys. I found some universal rubber mounts made by that HELP brand. They need to be trimmed but they look like they will work. Part number is 10665. I was really hoping for some oem ones. I'm going to stop by GM this week and try to find a better set even though the HELP ones should work just fine. I'm guessing something off a full size truck might work. I got a nice surprise too while I was searching for these pads. A guy here at my local auto parts store has a blown/nos SBC 240Z at the auto parts store. I'm wondering if the owner is a member here.....? Quote Link to comment Share on other sites More sharing options...
DavyZ Posted February 26, 2005 Share Posted February 26, 2005 Jaime, if you look a bit, the Volvo 240's have single upper units that are quite sanitary looking. I'm not sure how they'll do on the Griffin--is it flat on top? The Volvo upper mounts work well with the Camaro radiator like they were made for each other. Davy Quote Link to comment Share on other sites More sharing options...
jaime240z Posted February 26, 2005 Author Share Posted February 26, 2005 Thanks Davy. Yeah the griffin I have is a flat top with the tanks on the sides. I actually bought the JTR radiator mounts planning to use them with the griffin. Well, apparently the newer JTR mounts will only work with the oem camaro radiator. The griffin is just a bit too thick. The griffin core is fine but the tanks are too thick. It's a shame too because the JTR pieces are really nice! I'll try the pick and pulls but I haven't fiven up on GM yet. I'm going to try a couple more dealerships, otherwise I'll probably just end up using the "Help" brand uni. ones. Quote Link to comment Share on other sites More sharing options...
zcarnut Posted February 26, 2005 Share Posted February 26, 2005 What about these on eBay: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7956013292&category=33602 Powder coated and they have rubber pieces to cushion the radiator. The "Buy it Now" price is very reasonable. Quote Link to comment Share on other sites More sharing options...
maichor Posted February 26, 2005 Share Posted February 26, 2005 I made mine out of a mud flap from a big rig. I used the JTR lower support and cut of the the tabs front and back. It worked fine. I then covered the top with some aluminum angle from home depot. You can see it here under newes pics I think it was. http://photos.yahoo.com/maichor75104 Quote Link to comment Share on other sites More sharing options...
72zcar Posted February 26, 2005 Share Posted February 26, 2005 i second the volvo upper mounts. I used them on my 73 and worked good. I think there is pics on my web site. http://www.73zcar.50megs.com/photo3.html Quote Link to comment Share on other sites More sharing options...
jaime240z Posted February 26, 2005 Author Share Posted February 26, 2005 Hey thanks. I already the have metal pieces that I'm going to use for the install. I'm mainly just looking for the rubber pieces. I'll check out the Volvo ones! Thanks. Quote Link to comment Share on other sites More sharing options...
Guest ayrjam Posted February 28, 2005 Share Posted February 28, 2005 I used mounting rubbers from a 73-80 chevy pick up with a small block 400 or big block engine. They are made for the 3 1/2 inch tanks. Hope this helps. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted March 1, 2005 Author Share Posted March 1, 2005 I used mounting rubbers from a 73-80 chevy pick up with a small block400 or big block engine. They are made for the 3 1/2 inch tanks. Hope this helps. Yes! Perfect! Exactly what I've been looking for! I'll call the dealer in the morning, or back to the pick n pull. Thanks! Quote Link to comment Share on other sites More sharing options...
