Guest Junior720027 Posted March 3, 2005 Share Posted March 3, 2005 I was wandering if swapping in a 305 would be worth it. I have a buddy who is willing to sell it to me for pretty cheap. Quote Link to comment Share on other sites More sharing options...
Jolane Posted March 3, 2005 Share Posted March 3, 2005 This seems like a good start, where you can get going rather inexpensively, then eventually put a bigger SBC in. Joshua Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted March 3, 2005 Share Posted March 3, 2005 I heard 305s were best used for boat anchors, thats one reason they are so cheap. I contemplated a 305 swap before I deceided L28et, I asked around and even on this board people said they were junk. Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted March 3, 2005 Share Posted March 3, 2005 305 = 5.0L, and that makes people think of mustangs. Who wants that kind of image? I HEAR a 305 is lighter on gas milage. But it's gonna weigh about the same as a 350. 350 parts are far more common and cheaper. Just my $0.02 here. Quote Link to comment Share on other sites More sharing options...
Guest Magnum Rockwilder Posted March 3, 2005 Share Posted March 3, 2005 305 and 350 parts are one in the same, barring the obvious (crank, pistons). 305's are heavier than 350's (they have more metal; 350's have bigger holes (cylinders). 305's don't breathe well beause the bores are so small that they shroud the valves. 305's have a poor bore/stroke ratio, reducing overall power output. If you want to stay <250hp, a 305 would be fine. It'll be better than the L6 because of the low end torque output, and it'll still be capable of creating enough power to make the car get out of its own way, however, if you're patient enough and actively look around, you can usually find a cheap 350. I'd never pay more than $150 or so for a running 305, and even then I'd probably just wait and get a 350, unless I needed an engine QUICK. Quote Link to comment Share on other sites More sharing options...
Guest tony78_280z Posted March 3, 2005 Share Posted March 3, 2005 ..... 305 and 305 parts are one in the same, barring the obvious (crank, pistons).pistons).Type-o? I think he meant to say 350 and 305 parts are one in the same, barring the obvious (crank, pistons). Quote Link to comment Share on other sites More sharing options...
SSflyer Posted March 4, 2005 Share Posted March 4, 2005 A few years a go I transplanted a throttle body 305 into my S10 Blazer, and believe it or not that little sucker just flew. Yeah, a 350 is a way better choice, but you can probably get a very low mileage 305 with trans for $1300-$1500 bucks, maybe less. My Blazer with it's puny 305 toasted an awful lot of Mustangs... Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted March 4, 2005 Share Posted March 4, 2005 If the difference between you going V8 or not going V8 is a 305...I'd say drop the 305 in and have fun with it. It's better than no V8 at all right? Quote Link to comment Share on other sites More sharing options...
Guest Junior720027 Posted March 4, 2005 Share Posted March 4, 2005 Well it sounds like the 305 is out and a pursuit of a 350 is on unless I can get this mopar 440 from a buddy his dad is giving him till june 1st to get rid of it, if not he said I can have it, his dad just wants to toss it, lol Quote Link to comment Share on other sites More sharing options...
awd92gsx Posted March 4, 2005 Share Posted March 4, 2005 Remember that with a 440 you're pretty much going to be on your complete own since there is no kit, no instructions, no support, no anything available for it for the V8Z swap. Plus it would be much more expensive (I believe) to swap that in if you can even get it to fit. Quote Link to comment Share on other sites More sharing options...
Guest Junior720027 Posted March 4, 2005 Share Posted March 4, 2005 True and instructions are nice. Now I don't know. lol Quote Link to comment Share on other sites More sharing options...
Jolane Posted March 4, 2005 Share Posted March 4, 2005 I would just do a 305 if it is cheap, running well, and you don't want to spend a lot of money. You can always go to a built up 350 later with a simple swap. Joshua A 305 is a good engine, although power is not as high as a 350 (depending on the 305 and 350). My suburban 350 is rated for ~165HP I believe...pathetic stock! Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted March 4, 2005 Share Posted March 4, 2005 a 440 will fit http://http://65.100.60.50:8884/Files/Datsun/440cdi%20Dodge%20V8%20Z/ Quote Link to comment Share on other sites More sharing options...
Pop N Wood Posted March 4, 2005 Share Posted March 4, 2005 Don't spend $1500 on a 305. That kind of money will buy you a complete LT1 with trans from a mid 90's F body. Iron head caprice motors will be even cheaper. Those will "bolt in" with the JTR kit and get you a better FI with aluminum heads. Plus you will have an upgrade path available for 400+ HP Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted March 4, 2005 Share Posted March 4, 2005 Here is a 440 in a 280Z : http://ronruschman.tripod.com/car.html#car Quote Link to comment Share on other sites More sharing options...
Dan Juday Posted March 4, 2005 Share Posted March 4, 2005 Jolane is right. In my corral of vehicles I have 3 small block Chevy's, all FI. Two of them are 350's and the other is the 305 in my Z. All are in pretty much stock trim and guess which one is the most powerfull. Having said that, Pop-n-fresh is right too. If you have 1500 clams to spend on a motor grab an LT1 out of an f-body. IMHO this is the best bang for the buck in a Z swap. Quote Link to comment Share on other sites More sharing options...
patzky1 Posted March 4, 2005 Share Posted March 4, 2005 Yeah, a 305 is not a great bang-for-the-buck motor unless you are planning on having less than ~ 250 hp in the end (nobody here). I think they pretty much top out at 330 hp and that is with ALL the $$ goodies minus nitrous, turbo, or whatever. My beginning engine, the free 305, was factory rated at 145 hp and it had like 120,000 miles on it so it was actually putting out less I think. I researched what it would cost to make it over 250 hp (rebuild, pistons, cam, heads) and it was just as cheap to just get an already-done 350 good for about 300 from my dad's friend. Overall, I DID like the 305 and it was worth putting it in for starters b/c it was.....free! Pat Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted March 4, 2005 Share Posted March 4, 2005 Junior to give you an idea I just sold an iron head caprice motor with 88k miles on it, running when pulled for $250. Im sure you will be able to find a 350 at a descent price. Quote Link to comment Share on other sites More sharing options...
Jolane Posted March 5, 2005 Share Posted March 5, 2005 Another point of reference...I just bought a Vortec 350 (1997 I think) with all fuel injection (minus computer) components for $50. It spun a rod bearing, so add a few hundred for machining and it is not very expensive. No doubt that a rebuilt 350 is better, but if the price is right on the 305... Joshua Quote Link to comment Share on other sites More sharing options...
Guest Junior720027 Posted March 7, 2005 Share Posted March 7, 2005 Sorry haven't checked it in a while been busy, Thanks for all the options and ideas guys, now I think I'm gonna have to put a new tranny in my van, lol so it will take even longer than planned since I'm already saving every penny I find, lol Quote Link to comment Share on other sites More sharing options...
