looking 4 an old tread
I've got four old-tread tires under the house (one has some funny wires poking out of the tread though). $50 for the set?
Anyway, here was one thread I found. Unfortunately, quite a while back, a lot of strings were on the Chevy site when they should have been posted elsewhere. The key words are in the link below, and there are several posts associated with it. Good luck.
http://forums.hybridz.org/showthread.php?t=84740&highlight=pinion+angle+mustache
The original JTR manual had a write up on how to do it. Rather trivial to do. You need the diff flanges with the R200, but when I did it I don't remember replacing the half shafts. The R200 half shafts are suppose to be slightly shorter (in theory anyway), but i think there has been some controversy if that is really true.
Pete Paraska talked about driveline angles and his version of Ron Tyler's diff mount. Check http://www.alteredz.com
The search function flat sucks for finding old threads. The only way I have been able to locate some threads is to sift through all the old posts of someone who I remember posted in the thread. If you go to a member's profile page, there is a "find all posts by ____". Tedious but at least the list will be complete.
