How Much?
Guest Benito
Guest Benito
I've been poking around on this board for a bit over a week and noticed that a lot of you guys already have, or are in the process of having an RB 25/6 swap in your z-car. I have recently inherited 2 z's, both 83 zx non turbo m/t's and was looking at a stock restore for one and a 25 swap for the other. I'm NOT on a tight budget, but, of course, want to save money. Can you guys give me a ballpark figure as to how much you've spent for MOTOR/CLIP and INSTALL alone, basically just to get your car up and running and in drivable condition? Just weighing my options and wanted some input.
In the past, I've owned a '95 300zxtt, (a total peach-white with basic bolt ons, rims, skyline brakes-I can post pics if anyone's interested) and now I have a ZR-1 ('91 stock with under 30k) but I never drive it because I have it in storage. But since I have gotten rid of the Z, I've always had a craving for Nissan turbo power and the opportunity has finally raised it's head. I'm hoping we're talking under 10 grand here? I was leaning towards the 25 so I can play with more power-adders and do the swap right...
Guest JAMIE T
$7500-$15,000 if you do all the work. And, do it right. Do'nt kid yourself into thinking this is an easy "bolt-in". Believe me, a small block chevy is a whole lot cheap. I've got $25,000 in parts, no labor in my 240Z. Granted, I bought 2 RB26's and HKS turbo's. Those items were the big ticket items. One engine is going in the car with just bolt-ons and the HKS turbo's. The second one is getting fully built for serious power, as in over 800 hp to the wheels.
A quick run down on items you'll want or need:
Motor and trans
Engine mounts
fabricate a trans mount
custom driveshaft
improved differential
a big brake kit
suspension bushings
wheels and tires
boost gauge
boost controller
exhuast(don't skimp here)
Also, depending on the condition of the cars, you'll want to basically restore it to prep it for the engine swap. Hope this gives insight to the REAL cost of doing an engine swap.
im doing the swap r8t now and so far ive spent 1450.00 motor and 5 speed 450.00 race exhaust manifold and intercooler will spend about 1700.00on gt35r turbo and stand alone comp and harness, if u just do the basic swap rb25det are on ebay 4 about 2500.00 with all the bits u'll need for the swap less the mounts and oil pan which will be about 500.00 i dont see why it should take u over 10,000.00 with the good bargains going on r8t now, take ur time and u'll be fine as these motors gain popularity here in the u.s it'll get easier
Guest Benito
Thanks for the insight. I plan on making the car able to handle the extra power before I take the plunge, anyway, so it won't be for at least 6 months or more that I even start ordering parts. I want the suspension and brakes DONE by the time I do the motor. I may even go with a cage, too, as I had a nasty rollover in Jan '04 and have since promised never to drive a fast car without a cage again. As far as bodywork goes, the Z that is getting the swap already has a 90% (which is all it will ever have) restore with custom color metallic blue paint. It would've been 100% restored, but I only helped with the restoring process, I wasn't in charge (car wasn't mine at the time) This Z has 365k on it, but has never been driven hard, as it still has the original clutch with plenty of life left. O yeah. I am the second owner.
Guest Benito
The intake mani wasn't a "must have" for the swap though, was it? I would much rather have the engine in the car and running before I put mega bucks into mods. I'd just drop it back out to mod it out at a later time--aka when I have more money to do what I want to do. If there's one thing I've learned over my short 5 or so years of tuning cars, it's that if you aren't thorough and don't do a near perfect job, it will ALWAYS bite you in the *** at the end...
I mean, getting a nice front mount with custom piping and a bov alone is going to be over a grand itself. A custom mandrel bent 3" turbo back will probably be about the same. Costs add up quickly and it sucks running out of money halfway through a project...
Complete Motor + Trans $2000
Oil Pan $175
Intercooler $200
Intake Manfold $600
Flywheel $379
Clutch $300
List goes on and on and on...
Man! rb25det + that greddy manifold + one more grand and you get the Rb26dett... Better motor in every single way...
I did my math after getting a Rb25det, which I sold, and I'm just going to do the GT-R Stock Engine. Enough power, strong enough, and it is just a legend.
My recomendation: save money and be patient, get everything you need before start the swap.
The RB26 seemed to me like a good deal, but it was way too expensive. MAINLY because after getting the 26, I would have to go find the RB25 transmission which would be roughly a grand, sometimes more. (That would be about 4K+ for Motor and RB25 Trans) I bought my RB25 for 2K.
Also, my reason for getting the RB25 was the fact that it came in ECR33's (1995-1998). Most RB26's that are stateside come from BCNR32's (1989-1994) [Please correct me if I'm wrong].
I didn't want to put myself in the situation of having a motor from 1992, so I opted out for a newer RB25DET (not that much newer, but still newer).
The GReddy manifold is not a needed part, but I like the fact that it's a huge plenum that doesnt wrap over the valve cover. Reduces a lot of piping to increase throttle response.
So yeah, I probably could have done other things... but to each his own Z.
-Cheers
P.S. - I'm also saving up and buying all my parts before putting them into the car. Very good idea saves money and time in the long run. Especially clutch and flywheel!
Guest Benito
The GReddy manifold is not a needed part' date=' but I like the fact that it's a huge plenum that doesnt wrap over the valve cover. Reduces a lot of piping to increase throttle response.
QUOTE']
O yeah. I forgot about the silly intake mani on the 25. I think I'll break for the mani...
This has all been covered a bit, but what the hay!
Er... not quite.
I can almost gaurantee you that any RB26 you get for $3600 will NOT come with a tranny. So you'll have to hunt one down and can expect to pay anywhere from $1000 - $1200. And you'll need an oil pan' date=' fabricate a pickup...etc.
There are several advantages to going with the RB25 and, depending on the power output desired, [i']could[/i] be considered a better swap than an RB26. Notice I said better swap and not better motor.
'Better' is subjective and sometimes depends on personal factors... not HP, not # turbo's, not 'GTR'... etc.
Even thought the price of the '26's are falling (Although I seriously question the condition of some of these motors) the '25's are still cheaper!
I'm also thinking about the ATI Dampeners. But I need to see if the ones off the RB26 will fit the ones off of the RB25. I need to remove mine to compare it to the 26's. My crank pulley is a bit damaged and I'm affarid of balance issues, also it's nice because it removes all the extra pulleys I don't need (A/C and P/S).
Anyone know if the BCNR32 or the BCNR33/R34 crank pulley is interchangeable with the ECR33?
Guest JAMIE T
If the balancer in the your picture is of a RB25 unit, then it looks nothing like the one for my RB26. Checkout the pics in the thread "When in Doubt, Bling it out" for comparison.
FWIW, I agree 100% with Zhadman. For $3600, you will get an RB26 and maybe an AWD tranny. You'll still need to get a tranny. Then plumb the freakin' thing. Anyway, I saw good freakin luck to anyone thinking they can swap and RB anything into a Z for under $7500, and I don't mean halfassed approach, I'm talking about a complete system. Like savageskaterkid, his intentions were good, but he was talking about not installing an IC. He said he would do that down the road. Not the way I would approach such a swap.
If the balancer in the your picture is of a RB25 unit' date=' then it looks nothing like the one for my RB26. Checkout the pics in the thread "When in Doubt, Bling it out" for comparison.
[/quote']
That is just a general picture I think just go to give people an idea.
ATI makes two dampeners, one for the R32 RB26, and one for the R33/R34 RB26. The R32 and the 33/34 are different.
. Anyway, I say good freakin luck to anyone thinking they can swap and RB anything into a Z for under $7500, and I don't mean halfassed approach, I'm talking about a complete system. Like savageskaterkid, his intentions were good, but he was talking about not installing an IC. He said he would do that down the road. Not the way I would approach such a swap.
I did mine for under 5500 but i was in japan and had help with some very very reasonable prices (thanks MATT)
